Looking to replace my Carver C-4000 preamplifier (only because I'm interested in something with better specifications but I've loved it for decades). I want to keep it a stereo system but with time delay for rear and front speakers. Currently, I'm using the C-4000 as a line stage preamp that feeds a Schiit Audio Freya Noval Preamplifier that feeds two Vidar 2 Amplifiers being used as monoblocks. I'm still using the C-4000 because it has 1) a built in phono stage for my Technics SL-1301 turntable with a Hana SL MC cartridge, 2) a built in adjustable (volume and MS delay controls) time delay processor/amplifiers (left and right surround are output to a Carver AV-64 that additionally has a "derived center channel" output, and 3) an external processor loop so I can connect an Audio Control equalizer and Phase Linear Spectrum analyzer (so that I can occasionally adjust frequencies as my room has unusual dimensions plus a sloped ceiling from right to left - it was the only way to place my speakers - a pair of Dahlquist DQ-10's). One of the biggest problems with the setup is that I'm using left and right subwoofers (Audio Pro B2-50's) and I have to run the subwoofer signals (L & R) out of the C-4000 to the subs and then into the Freya Noval single ended RCA inputs. This also makes setting the subwoofers sensitivity difficult. Because of all of the advances in surround sound processing and the disappearance of simple time delay processors (ones that don't need a digital signal to do processing) this undertaking of looking to improve the surround sound specifications of my system seems impossible or not very feasible. There's also limited space on my Salamander audio stands to place new equipment. Should I just have the Carver C-4000 and the AV-64 refreshed or keep on my quest? I was considering using a Parasound Halo P7 preamplifier in place of the C-4000 but there's no surround sound processing and no adjustment for the phono stage like the P6 so I'd need an additional surround sound processor, multi channel amp(s), phono stage. Any thoughts would help. Would like to find a preamp that has balanced and single ended outputs that can be used simultaneously/external processor loop/two tape loops and a surround sound processor that can time delay process a stereo output with adjustable volume and MS delay control. I know that's a daunting task but it seems that there are quite a few really really knowledgeable folks here. Thanks.
