Relays that are "audiophile" grade
ehabheikal
Would cheap relays do anything if used to switch power to a dac or amp sound quality wise.
I ask to know if i could use common home automation systems to swith the power of my components.
egellings
So long as the relays are of good quality and meet safety code for use in a power line circuit, I see no problem with them.
antcollinet
UK/Cheshire
If you are talking about (for example) wifi power switches, or other designed for pupose kit, they will be absolutely fine and have no influence on sound quality.
Just as power cables, fuses, power outlets etc have no influence.
ehabheikal
Thanx
