longwaytofall
- Joined
- Feb 4, 2024
- Messages
- 9
- Likes
- 2
I have a troubling noise issue that I spent a fair bit of time diagnosing today. My amplifier (3e audio unit) is installed in my car, and is fed by a dc boost module to go from 12v to 48v. The amplifier is fed by a DSP, which runs on 12v. Because the DSP has single ended RCA outputs (not balanced), I modified the amplifier to accept the single ended input. I am getting a roughly 20hz tone (I think this may be PWM noise by a component in the car). My question is, is it possible the noise is being caused because the RCA cable signal ground is grounding to the 12v dsp and the 48v amplifier?
Here are the combinations I tried that made me suspect the signal ground:
DSP>3e amp=noise
Phone with usb c to rca converter>3e amp=no noise (rules out issue with amplifier)
DSP>amplifier/speaker outside of car (with long rca)=no noise (rules out issue with DSP)
DSP>commercial car audio amp=no noise (I'm not sure if car audio amps run fully on 12v throughout? Or they manage the signal ground differently?)
I also did several other things like run the dsp from a different 12v source to eliminate ground loops, tried different RCAs/shielding etc.
Another thing that makes me think an issue with the signal ground is that when I insert the RCA into the amp while it is carrying a signal from the dsp, I can start to hear the music when the middle signal pin makes contact without any noise, but when the ground connection is made the noise starts.
Any help would be greatly appreciated, I am stumped on how to address this!
DSP>3e amp=noise
