REL Stampede active subwoofer - UK
Count Arthur
£120.00 + £20.00 postage to UK.
I used this as part of my desk set-up with excellent results. The REL has high level inputs, which means it will work with passive speakers and amps with no dedicated subwoofer output. You run your main speakers at full range, then adjust the volume and frequency cut-off on the REL subwoofer to "fill in the bottom".
Includes high level input cable, instruction manual, remote and original box.
You can see the instructions here: https://www.manualslib.com/manual/140009/Rel-Acoustics-Stampede.html
There are a couple of marks on left and right sides, the mark on the left front corner in the last picture is about 5mm in length.
Feel free to ask if you have any questions.
Hi,
I should be able to do that for around the same price, £25.00 with cover.
