Long time listener, first time caller
I currently have the stack in the title and have been bitten by the same PA5 issues as everyone else. Trying to find a good replacement and the closest I can find is the E70 + L70 + PA7 stack, but I'm hesitant to get a topping amp again for obvious reasons. Things I really like about my stack that I'm hoping not to give up -
- Physical switches to toggle between inputs, on both the headphone amp and the speaker amp. I have both a laptop and a desktop hooked up to the same pair of headphones and the same speakers, and can easily toggle between the two sources and the two outputs
- They're about 5" high stacked, which allows them to fit nicely in the space I have
- Really good quality (when they worked)
My headphones are sennheiser HD800S, those aren't getting replaced anytime soon
Speakers are currently Klipsch RP-600M, will get replaced later this year with KEF R3 Meta. I sit about 2 feet from the speakers in a ~120 sqft room, they don't need to get horrendously loud
Anyone have a recommendation? Haven't found anything that seems nearly as suitable as the E70 + L70 + PA7, but would prefer to avoid topping. Budget is very flexible
