Haha, really good point
But to be fair, they mention that they've done similar tests with other setups and got the same result.
Watch your language. This is a professional forum. Warning issued.
Wow, that was tedious reading.
The problem is that your claim isn't supported by anything. You don't seem to understand that sighted testing has been PROVEN to be unreliable.Wow, that was tedious reading.
What I claim is that if I can hear a difference between two items under test, sighted, then I can identify them blind. If I can't tell the difference sighted, then it's not worth all the trouble to compare blind, and certainly won't provide any better results.
So, your mind works differently to a normal human's then? Everyone else has cognitive biases and needs to double-blind and accurately level-match the tests to get accurate results. I guess you do not work in medical research...Wow, that was tedious reading.
If like most with his ideas everything sounds different and everything matters.How often do you hear "differences", tho?
So you've yet to take the step just once to confirm if you hear a difference sighted that difference is still there for you blinded. It only has been pointed out like a couple dozen times. It is this last step that can set you free.Wow, that was tedious reading.
When doing modifications to gear, I'd say less then 40%. There is no ego to it. It is just experimentation.How often do you hear "differences", tho?
More often, I'd make several changes at once out of convenience and wouldn't be sure which changes made what difference. If I were a manufacturer voicing a component, modifying other people's gear, or publishing, I would take the extra effort and risk to change one thing at a time. There is indeed risk as today's products are not designed for lots of assembly and disassembly or parts changes and do fail from it. If I replaced a stack part with a superior one and heard no change, most often I just leave it in rather than risk damage by swapping back. Maybe someday if/when I increase the resolution of my system, it the change might become significant enough to matter.
I started modifying amps, preamps, CD players, DACs, tuners, and speaker crossovers since around 1985, after hearing the improvement made to my Hafler DH-500 by Musical Concepts.What do you modify? How do you determine changes, just sighted and by ear?
I do own an oscilloscope, capacitor, and multimeters, and had access to a electronic bridge for testing capacitor DA and ESR which I used to choose capacitor replacement candidates. My ears are the final arbiter of what is better, which should make sense given audio gear is for listening, not measuring.
I also make some recordings of grand piano. Mic placement is by sight and then adjusted by ear. This has been a gradual process and infrequent, so I've not invested much into it yet. The really subjective, lunatic fringe audio people are recording engineers, producers, and "artists". They drop crazy money on microphones, preamps, and effects to get the "right sound". I recently bought a Urei 1176LN Rev. D (circa 1970) for $20 at an estate sale and sold it for very stupid money because 75% of hit rock/pop records were made with it and every rich musician *needs* one for their recordings to get that hit sound.
Your ears are indeed the final arbiter of what sounds better for you, but it is presumptuous to insist your experience is universal and trumps the experience and knowledge of others.My ears are the final arbiter of what is better, which should make sense given audio gear is for listening, not measuring.
The problem with the world is that the stupid are cocksure, while the intelligent are full of doubt. — Bertrand RussellSo much ignorance, combined with a general lack of self awareness has become tedious indeed
