Actually I have a new idea. If a magnet can force all the electrons to the inside of one wire we could use the outside of that same wire to replace the opposite conductor! So the plus side (which everyone knows brings the signal) could all be forced to the center of the single wire. The minus side, which carries old, spent, worthless electrons, could use the outside of the same wire. Any external interference would go into the useless returning electrons. We would need only one wire from the amp to the speaker. I would call this mono-wiring. If you want to biwire using my system you would only need two wires. Note that today biwiring requires four wires total. I will refer to biwiring using my new magnetic holography as "true biwiring." All other biwiring would be "false biwiring."
