RCA Sucks - Why Do We Use It?
RayDunzl
Central Scrutinizer
Riverview FL
What's the next trick, putting paper clips in the power points or charging up a mains rated capacitor and chucking it to your party guests to play hot potato?
Our "new guy" initiation at work was to put a turn of 1 amp fuse wire around the end of an extension cord.
When he plugged it in, it made a nice flash, pop, and some smoke, and left an indelible black smudge on the receptacle plastic.
RayDunzl
Central Scrutinizer
Riverview FL
One guy got back at me, though.
Had to give a little job progress demonstration to The Customer.
At the end:
Me: "Do you have any questions?"
Customer: "Yes! Why is there a chicken leg on the keyboard?"
Shit happens in Louisiana...
I've been cleaning out the garage and storage, all kinds of things have popped up.
I found this sticker from that Telco. A bigger version was on the doors of all their trucks in 1984 (no longer, of course):
Ha...
RCA... Registered Coon Ass... Just noticed.
I guess the post remains on topic after all.
watchnerd
watchnerd
Seattle Area, USA
At the end:
Some kind of freaky voodoo curse?
Eaten, or like with feathers and all?
RayDunzl
Central Scrutinizer
Riverview FL
Mnyb
Sweden, Västerås
It’s should have been out in 1970 to make a difference, a very small percentage of humans still use anything with RCA in the first place ?
Jimbob54
Really? I mean, obviously the proportion of the world's population with anything resembling "separates" hifi is pretty small, but within that subset, the proportion with some RCA connections must be pretty damn high. Then you have the folks simply using RCA from TV to amp/ soundbar etc either because no spare HDMI or an old amp.
Speedskater
Cleveland, Ohio USA
These new connectors are about balanced connector footprint size. Well (TRS) 1/4 inch and (TRS) 3.5mm mini connectors have been around for a long time.
Their rational against 3.5mm mini is not very good. A problem with these connectors might be confusion between unbalanced stereo and balanced mono.
BNC has a problem of confusion between 50 Ohm and 75 Ohm connector mismatch. These new connectors will have the same problem.
JohnYang1997
China
4.4mm jack and plugs are getting much cheaper. I really disliked 4.4mm around 2017 because it's proprietary and expensive. Now I am even considering to use it to replace the bulky 3pin XLR connectors.
