I’m looking at Matrix 3 to handle the usb to aes conversion.
https://www.matrix-digi.com/product/82/X-SPDIF3
Kinda pricey but looks like a nice piece of kit
And now I’m thinking about a quality xlr cable to daisy chain the speakers together ( 10’ would do) and to make the connection from the usb converter to the aes input (a 3’ would do). Just a decent quality cable nothing to crazy. I’ve soldered up plenty of rca’s along the way but haven’t even used an XLR type.
Any ideas?
This is great , thanks so very much for your help
Jcris
To connect USB to AES, you can get an inexpensive, $30 device as
@tonycollinet notes above. I have no idea how these work and whether or not they're reliable. I have no reason to believe they're not, but I haven't seen a test of one.
If you want to step up from that, unfortunately most, perhaps all, devices that convert USB to AES start at $500 and up, like that Matrix SPDIF3 you found, or the MiniDSP Flex Digital Edition.
If you are willing to give up the AES output on the device, though, then your options open up a lot. For example, SMSL makes the PO100 Pro, which I think is only $70, and it provides USB input and SPDIF (RCA coax) output. (They used to make a non-pro PO100, which did the same job and cost about $40 or $50, but it's been discontinued).
With SPDIF coax output, you can buy a (relatively) inexpensive RCA SPDIF to AES cable to go from the PO100 Pro to the AES input of your device. Technically that cable should be a 110 ohm cable. Those are hard to find in my experience, but I know Sweetwater has them for around $35 depending on the length. However, if you have a relatively short run - like 6 feet or less, maybe even 10-15 feet or less, I'm not sure - then a regular 75 ohm RCA to XLR cable should work. While I was waiting for my 110 ohm Sweetwater cable to arrive, I got a $9, 75-ohm Monoprice RCA to XLR cable (added it to an Amazon Prime next-day order of other stuff I was already placing anyway). I tried the Monoprice cable and it works perfectly (I have a 6-foot run). When the Sweetewater cable arrived it looked nice, but the Monoprice fits nice and tight on the RCA end, so I just left it installed and have never even used the Sweetwater cable.
As for an AES to AES cable to daisy-chain the speakers, I would recommend getting one from World's Best Cables, which are sold on Amazon. Inexpensive ($35 give or take depending on length), 110ohm, aka proper spect for digital AES, works great.
So even if you want to stick to reliable name brands and active devices, I think you can get what you need for about $100-$130, give or take, including the converter device and both cables.
