Hi All,
I'm starting to build a PI streamer out of DIY curiosity and the ability to tweak and swap parts long term.
Right now I've,
Raspi 4 + Volumio --- over USB 2.0 port ---> JDS Labs Element (DAC+AMP) --- RCA Out ---> Receiver
I confirmed with JDS Labs that the original JDS Element can be used powered-off as a USB DAC (powered over USB itself). To quote JDS:
"Yes, the original Element relied on USB power for its DAC, consuming less than 100mA. "
This is great as I want to reduce cables that are running everywhere. I've noticed a strange effect, if I disconnect the power outlet from the Element completely, Volumio logs show that the USB DAC behaves as if it was detached and attached again. This causes Volumio to stop working. If I leave the power outlet plugged into the Element but keep it turned-off, Volumio works great.
I'm using a Macbook charger, rated at 2.4A for 5V (87 watts). I'm wondering if the DAC gets reset due to lack of power. Raspi 4 can provide a combined 1.2 A on the USB ports. I've a USB drive connected as well (though I don't know how much power that will consume). Raspi 4 suggests 3.5A @ 5V as input.
I've a dedicated 3.5A @ 5.2V power supply for Raspi on it's way.
I thought I'd check with the forum, what are people using as their USB powered DAC with Raspi and how are they powering their Raspi. Secondly, I'm not a fan of Volumio, I find their UX poor. For now, I'm using Volumio to arrive at a stable solution and then explore other streamer/software. What suggestions are worth trying.?
Right now I've,
