I am tri-amping speakers with 2 12 inch woofers 8 ohm in parallel, Small room, I listen at 75 to 85dbs. I am using a Parasound 200W or so amp.
would not a good 100W amp do the job. Same for the mids, I am using a 150W amp on 2 large dome 6 ohm resulting in (3ohms; I know) but does not seem to be a problem. Would not an 85W amp work? For the tweeter cut of a 5000hz 45W seems to work ok. All the amps are class AB. Electricity is expensive Here in Europe.
