Question about spade plugs for speaker cable
gasolin75
Denmark
If i use them for my amp instead of banana plugs because the normal long banan,bfa plugs is a little to long for my binding posts,
will they get loose over time as banana.bfa plugs won't, im of course talking aboy the spades connected to the binding post on my amp, NOT the cable to the spades
No, not normally.
A lot of people use bare wires or spades. (5-way binding posts have a hole you can stick the wire through and then screw them down.)
Turntable weights/clamps and now whether a connection is sufficient? Eh?
