Question about REW tone generator settings
GabrielPhoto
Hi!
If using the REW tone generator to check for amp clipping with an ocsilloscope ...I am setting my avr level at 3db below my max listening level so I don't "cripple" my sound too much but what do I set the tone generator to? By default is is at -12 dBFS
Thanks
There is no fixed calibration between dBFS and power or dB SPL. If you want to make a calibration you'll have to do it yourself (and then don't touch the analog volume control).
Be careful with high-power test tones into your speakers. A 100W speaker is supposed to handle 100W on the musical peaks and it might burn-up with 100W continuous tones. And you can fry a tweeter with even less power.
What I would do with a 'scope is just check the peaks with regular music at your "normal loud" listening level. If you can momentarily turn it up and the peaks go-up, you're not clipping. Once you can't go any higher you're clipping. But again be careful "searching" for the clipping level with speakers connected. It would be a shame to blow your speakers just to see how "loud" you can go!
