gamerpaddy
Hello
i repair hifi stuff for a while now and came across a phonostage from Trigon, model Vanguard 1 with a broken PSU.
after i got it back working (the power brick "volcano" was dead) i wanted to measure its distortion and noise.
I am using a Focusrite 4i4 3rd gen and REW software.
When a do a loopback with a short cable i get about 105dBFS N+D from the interface unless i increase the gain of the generator past -3dB
Also im using a phono converter that basically applies the RIAA in reverse and lowers the signal level passively to be able to hook line level RCA to a unused phono port.
so ive hooked it up like this:
all using RCA, not symmetrical.
REW Signal generator (1khz -12dB) --> Audio IF 1/2 Out --> "phono converter" -> Phono stage -> Audio IF 3/4 In -> REW RTA Plot
Apparently this is the result
the signal should be at -12dB but as i cant change the Gain of Input 3 and 4, its a little lower at -18dB. the Phono stage is at its lowest Gain (all switches off, default loading and impedance)
102.8dB N+D .. this cant be right, what am i doing wrong?
this would beat all measured phono stages by far if its correct.
How to measure it properly?
