Pre-amp with crossover
sigbergaudio
Norway
Looks interesting, are there any 3rd party measurements available?
Not to my knowledge. I have one though (we distribute them in Norway), sounds perfectly transparent to me. My understanding is that @Kal Rubinson have / had one too. There's a review in Stereophile.
thegeton
Manchester, WA
Still, a sweet looking piece of gear.
radix
I think you are looking for a crossover? they all have gain knobs
Yes, there are all sorts of electronic 2x4 crossovers in your budget. I'm not sure of which are best, but there's a lot of them. e.g. dbx 223xs is only $255 new, though you likely don't want rack mount?
TonyJZX
whole slew of behringers if you want to break out the manuals.
dasdoing
Salvador-Bahia-Brasil
Kal Rubinson
Industry Insider
NYC
I used it only for my multiple subs but it is capable of much more.
Yorkshire Mouth
Yorkshire Mouth
God's County - Yorkshire
Thanks everyone.
Annoyingly, that SMSL seems to show you can stick such a crossover as an added bonus in a cheap amp.
It’s a bit of a short-term solution anyway. I’ll be moving to monitors soon enough.
Thanks again.
Sokel
If you want something basic just as a crossover you can get away with as much as 40-50 euro if you can DIY a little:
V.b.
Berwhale
Is there such a beast as a pre-amp with a built in crossover/separate outs for mains and sub, balanced ins and outs?
Budget £100-£200.
Someone made one...
Crossover at 2.2Khz, but apparently it could be customized upon request.
Bit more info here: https://www.iwistao.com/products/el...nel-output-crossover-point-2-2k-hz-customized
JeremyFife
Scotland
XpanD
Netherlands
I wasn't a big fan of the pro crossovers I tried -- both my dbx 234XS and JB Systems XO 2.4 needed a lot of care with regards to turning devices on and off in the right order, or they'd send an insanely loud spike through my subs. Not fun hearing a loud bang followed by your subs deflating like balloons when you accidentally bump a power cable, or happened to still have something powered on...
I'm happy to be using a mix of surround receivers and software control (Equalizer APO) for my setups nowadays.
Joe0429
Arylic S50 Pro+ with SUB OUT. But it doesn't have balanced in/out.
Link
tc2007
Here's a crazy suggestion. Check your local FB / Craigslist listings for a used AVR from yesteryears, with pre-amp out. Plenty of Marantz / Yamaha / Onkyo etc. have pre-outs, at least for fronts. A used Marantz slimline is prefect in size, price and features if you can find one. Comes with a nicer remote too :p
Otherwise a used Emotiva processor / preamp would work too (maybe rare in your side of the world).
