Pioneer GM-D1004 Fuse
AzrielID
Hi, im new in this forum
I have a pretty stressfull situation where i want to upgrade my car sound quality (i have base audio EU variant, so the worst one)
I decided to upgrade the speakers with the Axton specific series (2 way on front + the woofers, coaxial in the back) and, for the price, they actually sound good.
Before buying them, i had a Vibe powerbox, but when tried to use the Low level input i found some issues with the front channel ground (litteraly no ground all over the circuit) and i decided to pick the GM-D1004 as a temporary amp.
I read about the fact can be capable of more, but the actual 15A fuse is the limit. Can be possible to put in a bigger amp? or could be some heat issues?
Just for info: already solved the issue with the front 3 way channel by installing a passive crossover (KEF KDN10, 250hz low pass)
That's the factory car-fuse, I assume? You can bypass it with a custom fuse if you blow it. The fuse won't limit current/power until it blows. ;)
12V x 15A = 180W. That's the power into the amp, and it's never 100% efficient. But since (hopefully) you aren't running constant full-power test tones, you'll only be putting maximum power on the program peaks and that makes it less likely to blow the fuse.
Heat shouldn't be a problem, especially with class-D. ...I've had a couple of subwoofer amps die and it was probably related to mounting in a place with poor air circulation. I've got class-D now and it's been OK for a couple of years.
Uh, thank for the fast reply, didnt expect that, i notice that i say "amp" while i wanted to type Fuse
Im a newby in the hifi world (will at home im running some KEF Q100 with a Onkyo TX-NR1007) and i actually dont know how the power rate and handling actually works
For example:
Front channel Axton b100c + Axton BSUB4 (60W RMS «i see on the tweeter about 20W» i dont know peak power + 150W RMS/300W Peak)
Rear channel Axton b100x (60W RMS, dont know peak power and tweeter power)
LINKs
On the pioneer site the Amp is rated at 45W RMS and 100W peak (and than 400W max), how can i suppose that the actual speaker would work fine without distorsion and the power will be enought?
And, if the max output power is rated at 400W, wasnt supposed to have a 30A fuse?
Forgive my ignorance in HiFi and audio in general ahah
