I recently replaced my decade-old sound system with the Klipsch RP line. Since my wallet was already open, I decided to fulfill an old dream and buy an Emotiva's XPA-3. Hastily, I bought it, imported it into my country, Iceland, and now two weeks later, I'm thinking: Is the XPA-3 an overkill for my Klipsch LCR?
My HT is a 7.2.2 running on an older Yamaha 2050 AV (I'm gonna go with Denon X4800 when it comes back in stock in Europe). My speakers are RP-8000F II and RP-504C II (specs below). My home theater is 19x13, and the main listening distance is 9 feet.
Between buying the XPA-3 and receiving it, I decided to buy the BasX A4 also (I should have thought this through). Now I have two weeks left to return the XPA-3 ($1499) and the BasX A4 ($699) back to Emotiva at my cost ($200 shipping) and I'm wondering if I should place an order for an OSD Nero HTA5200 5-Channel amp ($899) from Amazon.com and use the difference for the Denon AV.
I play movies at -24 (my sound level meter says 75-107dB where Top Gun Maverick peaks at 107dB) but I'm not entirely sure if all those dB's are coming from the fronts or the subwoofer (perhaps I should power them off and measure again?) I've been using the calculator on the Crown Audio to measure amp power required for the LCR but I feel that the calculations don't add up with my simple understanding of things.
If someone here can help out, that would be great. The staff at Customer Support at Emotiva suggested that I keep the XPA-3 as the speakers "need that 275w." - Can that be right? Is the XPA-3 an overkill, and the OSD Nero HTA5200 would suit my system better?
Thanks in advance!
Front: P-8000F II
FREQUENCY RESPONSE 35-25kHz +/- 3dB
SENSITIVITY* 98dB @ 2.83V / 1m*
POWER HANDLING (CONT/PEAK) 150W / 600W
NOMINAL IMPEDANCE 8 Ohms Compatible
Center: RP-504C II
FREQUENCY RESPONSE 50-25kHz +/- 3dB
SENSITIVITY* 96dB @ 2.83V / 1m*
POWER HANDLING (CONT/PEAK) 150W/600W
Surround:
FREQUENCY RESPONSE 62-25kHz +/- 3dB
SENSITIVITY* 94dB @ 2.83V / 1m*
POWER HANDLING (CONT/PEAK) 100W/400W
Thanks in advance!
Front: P-8000F II
Center: RP-504C II
Surround:
