Oh something like...?
I found that one but thought the word ‘ manipulative ‘ might be incendiary...
IF there was any summing the bass to mono on these LPs it happened in the mastering console that preceded the cutting amp.
The tapes were not modified in the case of the Mercury Living Presence recordings. The LPs were cut directly from the mixing console using the original three track analogue master tapes. Since these were three track masters it was necessary to mix them down to two channels in the console regardless of what other "modifications" may have been made on the fly in the mixing console. Same thing was true when they did the whole Mercury Living Presence CD series back in the early 90s. All of the original gear inculding the mixing console was refurbished and used for that series. Those CD also had to be mixed down form the three channel master tapes. IOW mastered for CD. So it was necessary for both the LPs and the CDs.Right. Exactly. That was the whole point of mastering. To take the original tape and modify it as needed to make a master pressing for the mass manufacture of LPs.
If this mastering process wasn't necessary, they wouldn't have done it. It takes extra time and money.
Note that I said "vinyl master". I didn't say master tape.
There is no hard panning on either the Decca or Mercury classical recordings. There was no mastering console whatsoever in the King Super Analogue LPs"In the old days, if there was a problem with hard-panned low end a mastering engineer "might" have to do the following:
Double the stereo track, sum one double to mono, high pass the stereo track, low pass the mono one, re-sum the two back together.. There were vinyl mastering consoles with this built in".
https://www.gearslutz.com/board/ele...nyl-pressing-just-general-bass-centering.html
The tapes were not modified in the case of the Mercury Living Presence recordings. The LPs were cut directly from the mixing console using the original three track analogue master tapes. Since these were three track masters it was necessary to mix them down to two channels in the console regardless of what other "modifications" may have been made on the fly in the mixing console. Same thing was true when they did the whole Mercury Living Presence CD series back in the early 90s. All of the original gear inculding the mixing console were refurbished and used for that series. Those CD also had to be mixed down form the three channel master tapes. IOW mastered for CD. So it was necessary for both the LPs and the CDs.
There was no "vinyl master" for the Mercury Living Presence LPs. They were cut directly from the "master tape."
but you can cut some large grooves and swings and get dynamics but your playing time will be in seconds or a few minutes per side...not good for selling music.
Watchnerd, here is something pretty cool to look at to
http://www.piratespress.com/products/direct-metal-mastering/
I would say according to the last two paragraphs they are trying to take away as many of the vinyl "pleasing artifacts" as possible, might not be the best way to go with the WBF brigade.
sEarlier on Analog Scott said he did not need to know how a cutter worked .
1. Yes, deep bass with high dynamic range can cause serious tracking problems particuarly if the bass is panned to the far left or right. Yes, there are recordings that contain such bass content that require modifications to be cut and played back on a vinyl record.Okay, let's go back to first principles. Do you acknowledge the following to be true:
1. Deep bass with a high dynamic range can cause serious tracking problems with LPs
2. #1, when coupled with severe phase differences between channels, makes not only tracking hard, but the actual cutting of the record difficult due to grooves running into each other
If you don't believe #1 and #2 to be actual limits in the physics of vinyl reproduction, then we need to backtrack completely.
Yeah, and an obvious working solution to avoid those compromises. The Analog Productions Top 100 Fantasy Jazz series that I cited were cut at 45 rpm with very short sides. Recordings that were originally released on single albums were all released in this series on double LPs.The exception being those 2 x 12" 45 RPM audiophile releases of material originally released on 1 x 12" 33 RPM, which, ironically, is direct evidence of the compromises in question.
That is complete B.S. Quote in context please. If you can't make an honest argument then there is no need for any further discussion.
No. The Mercury recordings do not have the bass summed to mono. The master recordings are three track recordings and the original LPs were cut directly from the three track analog masters. IF there was any summing the bass to mono on these LPs it happened in the mastering console that preceded the cutting amp. The recordings themselves do not have the bass summed to mono.
"RAB: I admire so much that you have mixed the three tracks manually towards two channels during the cutting of the record. I myself made audiovisuals and had to mix the tape with speech and the tape with music manually and synchronize it with the images. I had to start a fade-in at the right moment and finish the transition to the following image on preselected moments in the music, sometimes slowly and at times very quickly. If I made a mistake I had to start the whole program of 20 minutes all over again. I can imagine how intense your work must have been.
WCF: Yes, we never mixed the channels to a master tape, but always directly to the cutting lathe. A tape would introduce extra hiss and we did not want that."
The Mercury team used a Scully variable-pitch recording lathe designed by John J. Scully
and his son Lawrence J. Scully.
http://www.soundfountain.com/amb/mercury.html
OK so maybe this is a reading comprehension issue and not just plain dishonesty. Maybe you don't fully grasp the difference between "sEarlier on Analog Scott said he did not need to know how a cutter worked ." and what I actually said "I can cite well over 500 records off the top of my head that have no limiting, no compression, no EQ and no summing of the bass to mono pretty easily. I don't need to read up on cutting lathes to know these specifics about actual records that were cut this way" If you don't understand the huge difference between what I actually said and what you claimed I said then indeed, we should not discuss anything anymore from here on out.I can cite well over 500 records off the top of my head that have no limiting, no compression, no EQ and no summing of the bass to mono pretty easily. I don't need to read up on cutting lathes to know these specifics about actual records that were cut this way
There is no need for further discussion with me until you provide proof for your assertion and yes I reject a "block diagram" that does not back up your claim in my book.
Cutters cut records and lack of knowledge of how they work can lead folks to parrot what the back of record sleeves say, like most things, there is the rest of the storty.
Thousands of others perhaps agree with you, but I have not seen one post agreeing with you here yet!
I am sure there are plenty of things we can agree on but not this one.
So you had to with some ad hominem. That's nice. There's one logical fallacy in your argument. The next of course is your cherry picking. You cite the one block diagram but exclude the other block diagram and exclude all the written descriptions as well. So you have two obvious logical fallacies in your argument. This business about But let's look at what you excluded in your argument and see how it relates to the issue.Scott - you argue and argue as if you actually knew what you were talking about. But, presenting this as proof of your precious point about no mono bass on the LP blows your cover. If you think this proves your point, the rest of us are in head slap mode, because this schematic offers many opportunities to sum the bass to mono - mixing console, audio amplifiers, electronics, etc.
Where does his schematic say RIAA equalization is applied? Answer: it does not. Does that mean the Mercuries did not use the RIAA curve? No, of course not. But, that is what you are trying to tell us about mono bass - it is not on the diagram, so it must not be taking place.
And, by the way, no amount of stereo bass, even if it were there on LP, will solve all the miserable problems of LP mastering and playback. So, who cares anyway?
Reading comprehension aside, your only proof is the back of one record sleeve, and it is a simplified block diagram and not the statement you posted. It does not do it for me, it leaves out way too many details.
If you are saying that you read the back of record cover(s) and they say that" have no limiting, no compression, no EQ and no summing of the bass to mono", since you are very clever about the clarity of ones reading a comment, then yes, I agree with you, you just need to find me that comment on a record cover somewhere and we can agree.
Find it!
, and we can agree it was written on the back of a record cover or wherever it was written. Is that clear enough? If not let me know and we will wordsmith this down to whatever exactly you are going to prove or want to prove and have it correlated somewhere other than a statement you have made.
Or, you could just say I can not find anywhere to agree with my statement and then we can talk about something else, like measurements of phono cartridges, like I think the most expensive tech das one that rolls of at like 10KHz if my memory is correct. Now that's less than FM radio capability.
