I figured some folks would be looking for unreasonable over the top kinds of proof. Like "affidavits." If you actually read what was written along with the both block diagrams it is very clear that there is no EQ or use of compression or limiters. So the only thing you can contend in the summing of the bass to mono. While that may not be as explicitely addressed as EQ, compression and use of limiters I am of the opinion that it is addressed. You are not. Oh well. But again, I think whatever proof I bring you will find it inadequate.
Would an explicit claim by a mastering engineer of no use of EQ, limiters, compression and no summing the bass to mono in cutting records suffice as proof? Or would you write any and all such claims off, no matter how explicit as pure advertising fodder and a lie by the mastering engineer?
There is a phono cartridge that rolls off completley by 10KHz? Yeah, that would be something to talk about too.
Yes, if someone said that I would agree that they said that and agree that you have it documented that someone said that. Saying it is the only thing you can find. I would not ask for proof of someone examining the record or what circuits were turned on at the actual lathe. Really, it will give us all some relief.
No need to delve into the actual cutting process, as the words on that back page of the album you show are translations and I do not think are correct like: "no technical alterations are made to the master tape in the cutting process" well, the master tape is the source, it can be modified so the cutter works better, but they say they just ran with the master, Masters are made to play back over the tape machine. They can be modified to playback over vinyl better and are. Who knows what the master was set out to be in the first place, lots of ambiguous stuff on that back record jacket IMO.
