artshotwell
- Joined
- Sep 26, 2020
- Messages
- 20
- Likes
- 5
- Thread Starter
- #41
I notice the battery level drops fairly fast... It went from 100 to 83% overnight and I wasn't using it. I'm still working on turning off services that I don't need, so I may be able to improve that.The $110 Qudelix 5k works perfectly with LG Rebel via 3-wire OTG cable and USB. I have this combo by my bedside now - driving HE400i (balanced needed). Qudelix has a really great 10-band PEQ. You might consider it as a next step..
Not only can you tailor the headphone response, you might try adding a bit of boost in the 'dialog' range (500Hz-3kHz? Others with more experience advise?) and/or notch out any particular range that triggers tinnitus..
Now, whether to get new headphones or a Qudelix as the next step - I can't say. (Others advise?) - as I know nothing about the HD450bt. ( @solderdude?)
I'm partial to low distortion planar open back - hence my HE400i ($180). But I also use - a lot - a $79 Phillips dynamic open back - the SHP9500 (for tv, as it's extremely comfortable hours on end).
However, since you are ultimately thinking of HP replacement, and IMO need PEQ in any event, I personally would get the Qudelix first - and try it with the HD450bt you have. Then, if I were unhappy even after doing my best with PEQ, I'd then be considering HP replacement..
Note: this is the OTG cable you need to connect the Qudelix (also using one of its supplied cables) to the LG Rebel:
https://www.amazon.com/dp/B07B6CRW6D/
When you power the cable thru the female microUSB connector using the LG supplied usb power brick, both devices will be powered from it.
