Have you tried flashing the device?Yes, but the same problems remain.
Things have settled down for me. It's been over 24 hours and all the connections are working.That's what I'm asking the store to send me file 1 without updating it or to show me a way to leave it from the factory without updating it. The engineer still hasn't found the bug we have.
I tried it about 20 times, it didn't work. Do you remember the exact step by step of what you did?I reinstalled the usb driver, and then hit reset, and since last night, things are working OK
The process that I think worked is:
Reinstall USB Driver
Reinstall Update
Press RESET in menu
Sounds fine and I haven't noticed any problems. LDAC and AptX are supported, checked on Android (well, it's hard to be sure, but the device displays them as in use at the time of playback). I assume it's exactly the same chip as in the a300, so there are no differences in terms of BT functionality / sound quality.Hello. please tell me how this amplifier sounds via bluetooth? Really great compared to older smsl models?
In general, what model of Qualcomm chip is inside there.
Hello,Update.
I bought another one from Ashoida. (Again black)
I spoke to them and they knew nothing about these problems.
- The beeping of the tweeter is gone. (Which was my main problem)
- No beeping but a small amount of pink noise in the tweeter. It gets louder at higher volumes (50+). But this is not a problem for me. You really have to get your ear close to the tweeter. I consider this to be normal.
- The flickering in the display is still there, but thats not a problem for me. (ofc it is still not right to sell such a product)
The A300 model does not support the LDAC codec; it should sound worse over Bluetooth.Sounds fine and I haven't noticed any problems. LDAC and AptX are supported, checked on Android (well, it's hard to be sure, but the device displays them as in use at the time of playback). I assume it's exactly the same chip as in the a300, so there are no differences in terms of BT functionality / sound quality.
YesHere's a couple of pics of the interior of the AO300 from the audiophonics website.
I haven't noticed any heat from the unit.
That's one of the attributes of the MA5332MS, so apparently no need for a heat sink and it has a smaller footprint.
But that black thing in the middle, is it a heatsink?
Have some connection problems with Bluetooth, have to often try many times to get a connection.
I probably had the latest firmware from the very beginning. There were no problems with clicks and other things. I decided to flash the firmware from the site. And I got that when turned on, DoP 2.8224 MHz is displayed and there is no sound. It was necessary to turn off and turn on the amplifier from the remote control. I wrote to support with a problem. I was sent the previous firmware. I flashed it and got clicks. I decided that it would be better to have a problem with logging on than with clicks. I flashed it again with the latest firmware and Lo and BEHOLD. All the problems are gone, everything, along with the clicks and the USB connection.
I am posting the firmware that was sent.
I think you can try using a virtual machine to emulate WindowsBasically, this unit is probably okay after FW update if you're on PC, but Mac users should look for something else since S.M.S.L. doesn't seem to care that there are people who don't use PC out there.
