Newman
- Joined
- Jan 6, 2017
- Messages
- 3,606
- Likes
- 4,482
I don’t think much of your suggested use case. Not sure B&O meant it that way either.The reason the Beolab 90 is so unique is that you can tailor the sound to the recording.
For instance, I have really well recorded albums that are well suited to a narrow directivity speaker. The kind of recordings where you want to extract every last bit of information and you don't want the room coloring the sound. For that, use the 'narrow' mode.
I also have recordings that are pretty crummy. For those, the additional ambience that you get from the 'wide' mode can provide a forgiving presentation for an iffy recording.
It's a really neat trick
Given that you are almost certainly talking about 2 channel playback when discussing Beolab 90s and using them this way, let’s remember that wide dispersion is often preferred for 2 channel even with reference grade recordings. Using narrow dispersion and relatively restricting the soundstage to a thin line between the speakers doesn’t make sense.
And as for ‘crummy’ recordings, they are far more likely to have issues with their spectral balance than their reverb, so better to adjust the bit that’s causing the problem, with a decent tone control. Furthermore, if I wanted added ambience, that’s not the way to do it.
cheers
