Springfeel
- Joined
- Apr 19, 2023
- Messages
- 23
- Likes
- 11
Hi all,
I am currently running a setup such that I have a PC and TV, which use USB and TOSLINK respectively to connect to a DO 100 DAC -> Buckeye Amp. I made a REW profile to apply an EQ filter to my PC audio and would like to be able to apply it to all sources. I have read that you can load an EQ profile on the Raspberry Pi 4 and process the signal before passing it to the DAC. Unfortunately I am new to RPI and have some questions and concerns. One being that adding a RPI4 to the flow could negatively impact sound quality. I have also read that the RPI4 is unable to handle accepting signal from multiple sources with different sample rates and I don't know if there is a practical solution that won't affect sound quality. I know there are some members that have worked on similar solutions and would be grateful for recommendations on what hardware/accessories I will need? Thanks.
