pogo
- Joined
- Sep 4, 2020
- Messages
- 2,750
- Likes
- 1,118
Of course, you have analog direct for the left and right channels. Perhaps the block diagram makes it easier to understand:If you have a setup with subwoofers and the subwoofers do strange things when "analog direct" is engaged, then there is no "analog direct"
I have highlighted the parallel tap of the analog signals in yellow up to the sub-outs. In analog direct mode, the sub-out signals should be suppressed (firmware update needed).
Currently, you can simply switch off the subs if you want to listen to pure analog.
or
