What source will you plug in to the pre-amp?Thanks. I wouldn't want 2 boxes and cables to achieve a streamer preamp, and presumably 2 remote or apps to control the pair in your system. I'm sure Anthem DSP is similar to Dirac Live and I've had experience of both - with Anthem in a Martin Logan speaker system I had for a few months. I'm not an advocate of any "room correction" DSP that requires the entire frequency range to pass the filter, even if only the bass is adjusted, although the ML speakers applied Anthem to just its bass amp. Any other suggestions for a single-box streamer preamp? I have a short-list but most are 2 to 5 times the price of the M66.
If, like me you have an analogue source (Pioneer SACD Player) and a multichannel receiver (NAT T778) to integrate, and share the subwoofers between the stereo pre-amp and the multichannel receiver, then you better remove M66 from your short-list.
Sound quality-wise, I am pleased with M66, and also with the streamer I am pleased.
It is the pre-amp functionality for other sources than streaming that sucks. I think the biggest mistake with M66 is to let the BluOS app be its control. I am sure there are certain limitations with BluOS, and this could be one of the reasons why so many issue remain unresolved.
It should have had its own OSD and setup menu. It has on OSD but limited to the touch screen, and it does not have all settings (e.g. Audio settings), that you must open BluOS app to set.
Audio settings should have been per-source, like each source must have its own audio properties.
In any case - good luck with your search, and do keep me posted, as I am also in the looks for a replacement of M66. So far Anhem STR is the only one in my list.
