NAD 3020e output impedance and aux/cd
MrNice13
Switzerland
Hi everyone
I'm still new in the HiFi world and I would like to know if someone know the output headphone out impedance of the NAD 3020e as I don't want to drive 56 ohms headphone if it's too high.
I currently have it hooked up with some old missions speakers but I don't know if I can plug a DAC in the aux/cd input via RCA. I have a old smls SD793ii that can work as a dac and if so... I can plug it in the NAD if it's possible. And also.. does the aux/cd can be plug to a cellphone with a Samsung USB C dongle ?
Thanks a lot
Jimbob54
Don't know about the headphone out but you should be fine plugging either the dac or the phone in via the aux rca
MrNice13
MrNice13
Switzerland
Thanks. I read somewhere that the headphone output impedance of the nad 3020 was something like 200ohm.
It's seem so high and impossible. So it's technically impossible to plug my phone in the aux via RCA and 3.5 as my source and listening with the 668B if the impedance is so high.
Thanks again
Doodski
Thanks again
It's 220 Ohms.
restorer-john
The output impedance is indeed 220 Ohms and that is perfectly normal for connecting headphones to the power stage of an amplifier capable of otherwise destroying delicate headphones in a split second...
If your headphones have a flat enough impedance curve, you'll be safer.
restorer-john
Need better labelling on these schematics. :p
Hand-drawn. I love them. And if you find a mistake, you know it was a human who drew and annotated the schematic. Most likely, it doesn't matter as you have the device and the second channel on the schematic to crosscheck.
Have a look at the current Marantz/Denon AVR schematics in SMs. They are illogical, poorly laid out, jump all over the place and honestly are utter garbage. Compared to the gold standard Sony, they look like 3 year old kid's fingerpaintings.
Doodski
Where does one get the current models of Marantz/Denon AVR service manual schematics?
MrNice13
MrNice13
Switzerland
Thanks for the reply guys.
Damn 200ohms. So it's not recommended to listening from the phone out of the Nad with low impedance headphone if I understand..so why put a headphone sockets on these. But the sounds with a good DAC plugged to it and with good speakers is so GOOD. So warm. So if I have my cd player plugged I cannot listening from the phone out even with 250 ohms cans? :( sorry for my bad English.
Jimbob54
You will get sound out of the headphones. Depending on the headphones you might get an impact on the frequency response due to varying impedance. What are you using?
AnalogSteph
.de
It is not so much a matter of headphone impedance itself but rather its variation. So e.g. planars of 40 ohms would not be affected much at all (their impedance response tends to be nearly ruler-flat), but 50-150 ohm Sennheisers with their much more variable impedance response would be npticeably colored.
Speaking of which, if speakers sound super warm even in comparison to other amplifiers (despite tone controls being at neutral and loudness being off) this could be a sign that the switch contacts in the headphone jack may appreciate a cleaning...
The most common fix for a problematic headphone output is connecting a headphone amplifier to the tape (recording) out. With a unit sporting a mechanical input switch like the one in question, that signal path generally keeps working even when the speaker amp is turned off.
staticV3
How could a dirty headphone jack affect the speaker output ?
twsecrest
California
An 56-Ohm headphone can be driven by a headphone jack with a 220-Ohm output impedance, but there will be poor damping control.
It will give the headphones a bloated (louder, less detailed) bass and other weird sounds.
I would suggest investing into a modern headphone amplifier.
twsecrest
California
I'm guessing in the old days a lot of headphone sold were in the 250-Ohm to 600-Ohm range.
For use with home speaker amplifiers and in recording studios.
Building a dedicated headphone amplifier into a speaker amplifier or receiver adds costs to manufacturing.
It's cheaper to just run the headphone socket off the speaker amplifiers, which gives the headphone jack a high output impedance.
restorer-john
Actually, most home 'headphones' were modified 8R 2 1/4" speakers and then small 25-80mm mylar dynamic drivers with impedances from 8R to 50 or 60R.
The NAD output impedance is fine. There's so much BS being peddled in relation to low Z HPAs.
MrNice13
MrNice13
Switzerland
Superlux 668B, Dt770 80 and 250.
MrNice13
MrNice13
Switzerland
I think is the NAD warm signature.
I don't see how the sound could be super warm because the headphone socket could be dirty... BTW the unit was cleaned before I buy it and it was a good bargain.
