Multichannel Full Digital Amp (FDA) solution
Music1969
Here is a new "digital amplifier" but has a CS DAC chip before it
voodooless
Netherlands
It's not a digital amplifier, just an analog class D amp with a conventional DAC in it, like so may others.
Music1969
Noted. False marketing then by SMSL
"German Infineon's new digital high-power amplifier chip has higher quality,"
Fenwick972
Hi pptaki,
I've actually same full digital setup project in mind.
One question: how do you handle main output volume? Is it from the digiface or the A30As?
Thanks for answer
P
ppataki
Budapest
Hi pptaki,
Thanks for answer
Volume is controlled upstream in Jriver using Jriver's internal 64-bit volume control (best possible quality when it comes to digital volume control)
