Cool demo from Grass on their very low noise microphone (G.R.A.S. 40HF ):
Um, why isn’t this technology in ALL studio recordings
It is a shame we can’t have 300db SNR mics. What about a coaxial or tri-axial(?) mic that is microprocessor controlled to switch the lower ones off as the levels get higher?
But then I went to -400db and started hearing angels talking to meOh, but we do have those. The problem is that they are both permanently attached to Rob Watts head.
I have a microphone that is rated at 4 dbA for self noise. Only 6 db higher than this one. I've not tried recording caterpillars or leaf munching snails. I'd suspect the issue might be the low noise preamplifier. My microphone is rated for 29.8 mV/pascal while the G.R.A.S. is 1.1 v/pascal. I assume that is with their preamp in use which probably provides 30 db of gain or so.
If you do the research the slack diaphragm is one of the tricks.I used GRAS 43BB. Obviously, the noise level was low, but the maximum input limit was low. Difficult to measure earphones simulating ear canal resonance (+8 ~ 18dB) at 3kHz
In addition, since the microphone diaphragm is very flexible, it is necessary to couple earphones and stabilize for 1 minute. Otherwise, you can see the measured value continuously changing for one minute.
