Meta-Database: List of Audio Databases & Resources
pozz
pozz
Слава Україні
Editor
pozz
pozz
Слава Україні
Editor
Just added a bunch of audio-related calculators to the first post.
sweetchaos
The Curator
BC, Canada
Rja4000
Liège, Belgium
Audiifanzine.fr is a well known resource for musicians.
Sometimes, you see an AP measurement in a review.
Dennis Murphy
I made it through about a dozen of the hifinews lab reports, and the measurements, albeit limited to on axis plots, seem to be consistently less flattering than on other sites, including ASR.
Here's one for the Revel Performa F228Be
Perhaps they're shooting these with the grills on? If so, their waterfall plots would be pretty meaningless. So I dunno. Here's the SVS Prime Pinnacle
And the Focal Chora 826
MarsianC#
Austria
pozz
pozz
Слава Україні
Editor
Care to help?
https://github.com/freeDSP/freeDSP-aurora
Forums:
https://www.diy-hifi-forum.eu/forum/forumdisplay.php?251-auverdion (German)
https://www.diyaudio.com/forums/dig...usb-audio-dif-adat-bluetooth-wifi-contro.html (English)
Status: I'm not a software guy, but I try to help. I know there is still a lot of work to be done. Testing, coding...
PS: "software developed by members"
I think this should be posted to its own thread with a description of the project. It looks interesting at first glance.
pavuol
EU next to warzone :.(
Just one not-so-important issue, electronics review entries functioning as links to particular ASR reviews but not so with speakers?
pozz
pozz
Слава Україні
Editor
AurekV
MSO (Multi-Sub Optimizer) https://www.andyc.diy-audio-engineering.org/mso/html/ is a free subwoofer optimization program (Windows only) that provides results comparable to Dirac Live Bass Control and Harman SFM as far as flatness and seat to seat variation. EQ, level and, delay settings can be input into various DSP units and software. Really useful IMO.
pozz
pozz
Слава Україні
Editor
I'm the in middle of reworking the material in the first and second posts into a Google sheet. I created tiers from 1 to 4 based on usefulness. Some sites I'm more familiar with that others, so I would appreciate comments about whether or not the ranking is fair.
Edit: See post 1 for the link.
pozz
pozz
Слава Україні
Editor
Finished the update. 106 unique main databases and review sites with measurements listed and ranked.
pozz
pozz
Слава Україні
Editor
Slight reorganization. Main list holds only audio measurement databases (119 unique so far).
Other databases, with measurements or not, were moved to the second list.
pozz
pozz
Слава Україні
Editor
