https://linearaudio.net/record-replay-riaa-correction-digital-domain covers the DSP in some detail, plus a section on coupling cartridge and interface.I've always thought a good microphone preamp with an audio interface would make a good phono preamp as well as a tape head preamp because the RIAA and NAB EQ can be done with DSP.
Audio Precision has too high of noise to test EIN for mic preamps. If it's for testing distortion and such, then it's fine. IMHO people I know don't cares about distortion with mic input even though E2x2 excels at this. Maybe just knowing when the input is clipping is good enough. But I'm ok with testing distortion. To test EIN, the kind of resistor termination I made is kind of a must.AP has selectable output impedance ranging from 40 ohm to 600. The error at 40 ohm is pretty minimal even for low impedance interfaces. Is this your concern?
I'm not sure if max gain for Hi-z input is really meaningful. Max gain + Hi-z = Crazy noise.Many pro interfaces have at least one mic input which can be switched to high impededance (hi Z) for e.g. guitars. Might be useful to measure this input's impedance and max gain.
Of course we are not going to use the AP for noise measurement if the standard is 150 ohm. I thought he was referring to something else such as miscalculating the gain with high impedance (AP) source.Audio Precision has too high of noise to test EIN for mic preamps. If it's for testing distortion and such, then it's fine. IMHO people I know don't cares about distortion with mic input even though E2x2 excels at this. Maybe just knowing when the input is clipping is good enough. But I'm ok with testing distortion. To test EIN, the kind of resistor termination I made is kind of a must.
Can't you just use an appropriate voltage divider between the AP output and the MIC input, or would Johnson noise of those resistors be too high?Of course we are not going to use the AP for noise measurement if the standard is 150 ohm. I thought he was referring to something else such as miscalculating the gain with high impedance (AP) source.
really? - music professionals - imagine that!... : )You would be surprised at the number of professionals (in music production) that read our forum. That is why I test audio interfaces to begin with.
and aes wasn't supposed to cut you short and 'own' pub-rights on your paper... life's tough... : )What? The food was not supposed to be free! @AdamG247, I trusted you with this and now I hear you are handing out food for free!!!
60 db is pretty common, but if you want all of them, less than 50 db is very uncommon. Most are between those 50 and 60 db values.So what is a pre-amp gain that is on the high side that is supported by all products? Is it 50 dB? Or lower?
The preamp gain doesn't mean much.So what is a pre-amp gain that is on the high side that is supported by all products? Is it 50 dB? Or lower?
Well it does if you want to measure EIN equally across all interfaces. I tested the Topping E2x2 and it gets its best number at max gain but then drifts lower as you reduce gain. I thought it was you that brought up this point.The preamp gain doesn't mean much.
It does, for sure, vary with gain.Well it does if you want to measure EIN equally across all interfaces. I tested the Topping E2x2 and it gets its best number at max gain but then drifts lower as you reduce gain. I thought it was you that brought up this point.![]()
Well, this is why I was trying to pick a lower value "max" gain as to avoid that.As @JohnYang1997 wrote, you don't know how much of this "gain" is actually analog and how much is compensated for in the digital domain.
