Keith_W
How do you see the RT60 is not a reliable indicator?
RT60 = "Time for a reverberant field to decay by 60dB after the early decay time". "Reverberant field" and "60dB decay" do not make sense in small rooms.
First, the 60dB decay. The typical noise floor in a listening room is about 40dB. This means you need to measure in excess of 100dB to obtain a 60dB decay. Not a problem for a pro audio speaker, but typical domestic speakers have trouble. So we typically measure 20dB decay or 30dB decay and extrapolate it to 60dB (T20 and T30 respectively).
Now "reverberant field". All frequencies form room modes. Long wavelengths form fewer, and they create well defined patterns. Shorter wavelengths form hundreds of them. The definition of "reverberant field" is "thousands of overlapping room modes" that is the same SPL everywhere it is measured in the room. In a concert hall or basketball stadium, the RT60 remains the same no matter where it is measured. That's not true of your listening room - it is too small to form reverberant fields in all but the very shortest of wavelengths. You can observe it in your two RT60 measurements - see how they are different to each other. So it is more accurate to call it RDT - "Reflection Decay Time".
I don't know how to interpret REW results, I guess that in that small room I should go for a sound absorbers rather than diffusers? What would you recommend to put as a absorber on the rear wall? I'm thinking of 8 60 cm x 60 cm modules for absorbtion, maybe the top 2 of them on a sides with build-in scatterer? I'm affraid that with added curtains and carpet I'll absorb too much of highs.
Regardless of what I said, we can still observe a general trend that your RT60 is too high. You should try to bring it down by about 50ms. This can be accomplished with furniture alone (as per Toole) but if not, I would suggest some absorbers behind the listening position since that is the closest wall to the listening area.
You are quite right to worry about creating spectral distortion with inappropriate treatment . It looks to me as if your problem frequencies are from about 300Hz upwards. Absorbers need to be 1/8 as thick as the lowest frequency you want to attenuate. 300Hz has a wavelength of 1.14m, so the absorbers should be about 14cm thick. As you may be starting to realise, 14cm is already very thick and it would have to be unbelievably thick if you wish to absorb lower than this. I would start with 2 panels and add more if you need it.
As for the low freqs, once again - forget Helmholtz resonators. DSP is by far the superior tool.
