A diagram of my setup:
Dirac Live is set up with "Focused imaging" and measured in all 13 points.
Here's how it's measured and my target:
The latest addition to my system was miniDSP SHD and it made a significant improvement in my sound quality with the following:
- Flexible crossover that allowed me to smoothen the bass FR curve before EQ and eliminate big dips under 100Hz.
- Dirac Live - an easy to use room calibration system that delivers a very audible and very significant improvement in subjective clarity, imaging and soundstage. A/B compared it to my own REW-based calibration with the same target curve and Dirac Live sounds much better to me.
Why have RME ADI-2 in the speaker chain at all?
Loudness, Bass/Treble controls. Dynamic Loudness being most important for increasing the bass and treble up to a defined amount in a defined dB range to equalize for the perceptual differences in volume of different frequencies based on Fletcher–Munson curves. Essentially I get tonally balanced sound from high down to low volumes instead of it sounding progressively "duller" with lower volume. Important feature for me as I often listen to music at low volume late at night.
Overall my system is great and I'm super happy with it. Objective performance of the electronic chain should be close to transparent even with the additional DAC+ADC in the chain, amplifier is SOTA class D, speakers are well-measuring and well-reviewed, subwoofer is... at least big.
My question is - what upgrade could bring in the most bang-for-the-buck audible improvement in sound quality for my system?
I've prepared a poll with a few answers, here's some more details on each of them:
- All digital chain - remove DAC+ADC and upgrade DAC.
This means upgrading to RME ADI-2 Pro for its digital output which goes in miniDSP SHD and then digital to two new SOTA DACs for an all digital chain that removes the unnecessary DAC+ADC and upgrades the DAC in the chain. - Upgrade subwoofer.
Infinity R12 is a cheap subwoofer that has no published measurements. Anything else is probably better than it - Rythmik, REL, SVS, even Monolith. - Upgrade speakers.
Elac DBR-62 are good speakers, but likely Revel M106 will sound much better. Speakers are the first thing to upgrade they say. - Speakers are fine, upgrade headphones
If you think the speaker chain does not need improvement, but there are better headphones. HD800s, Aeon, Sundara, etc. - Everything is fine, enjoy the music.
Audible improvements might be possible, but they won't be significant or would be too expensive to consider.
