Is it possible to have a personal resonance of around 600Hz?
LakeWorthB
I have just started to really listen to classical music, and noticed a bad resonance at a certain frequency, thinking it was my headphones, I have tried another pair, and it is still there. It sounds just like a resonance of something, but inside my head. Using EQ, it is around 600Hz, and thinking that it must be me and not both headphones. So my questions are 1) Is this possible, 2) Is this common 3) How do I deal with it?
voodooless
Netherlands
600Hz is rather low for something in your head. The wave is about 57cm in length..
Why not try with a sine generator? See if you can find the exact frequency? There are plenty online generators out there.
kemmler3D
San Francisco
And more like 2.5m in water (better medium for judging wavelengths inside a head)...
So it wouldn't be a resonance in your head per se, but it's possible you have an anomaly with your hearing at 600hz. Not everyone has the same equal loudness contours.
https://www.szynalski.com/tone-generator/ I use this tone generator a lot if you want to figure out the exact frequency.
Q) What are the headphones you're using? It's not impossible for them both to have a similar problem with their responses.
To answer your question, I think it's possible. It's not rare for people to have personal "problem frequencies". It would be pretty uncommon for it to be as low as 600hz. And, to deal with it, I think EQ is your best bet. And/or getting your hearing checked out.
fpitas
Northern Virginia, USA
DVDdoug
I'd guess both headphones have a similar characteristic.
You listen with your ears all-day everyday, to speakers and all kinds of natural sounds, etc. If you had a "resonance" or bump in your hearing response, you'd be used to it and it would probably seem natural to you.
And there's nothing wrong with EQ if it improves your listening experience! ;)
Madlop26
I do have a "resonance" hearing problem, agree more like a personal frequency problem; has to be piano, when it hits the particular frequency sounds louder and distorted, happens in different headphones and speakers.
Sal1950
The Chicago Crusher
Central Fl
??? Best asked to a ear doctor !
About 40 years ago I had damage in my left ear from an unprotected rifle shot while at the range. It would cause a buzzing- distorted sound at a certain frequency when it would get excited. I'm sure it was way above 600hz but that doesn't mean yours can't be there. Being the audiophile music lover I was-am, I was broken hearted that might have to live with it all my life. I spent 3 or 4 months wearing ear protection in that ear all day and thank God it slowly cleared up. Ever since I'm totally anal about protecting my ears from very loud sounds.
Go to the doc. ;)
DRMLFL
Germany
Hello,
I am not an doctor/ENT but as a hearing care professional I understand a thing or two about the hearing process.
1) yes, this is possible. To calm you down, this is nothing to panic.
2) Could you please try it just with a simple sine tone generator? Is this on both ears or only on one side? Does it have a certain loudness range where it appears? Is it at lower levels or higher levels? How "wide" is the resonant frequency (like the q-factor or bandwith of an equaliser)?
I remember the first week as an hearing care professional apprentice I wanted to check the audiometer. First, I thought the right headphone speaker was broken because I could hear a grainy, distorted ringing with different overtones @ 1 kHz between -5 and 25 db HL, but it disappeared at 30 dB HL and louder. I asked my instructor if she could hear it too. No was the answer. So I switched the sides of the headphone to hear the result. Exactly the same and I realised that there is something resonating in my right ear. With a tone generator in my case the "resonance" occurs from 996 Hz to 1002 Hz. Below or above those frequencies i can a hear a pure sine tone. Like I mentioned before, the resonance has a more grainy character, something like bit-distortion or a lowered sample rate via VST plugin.
It could be everything from the tympanic membrane (a little perforation or scar for example), ossicles, cochlear (inner or outer hair cells), or even just because of the shape of your ear canal. It could be also ear wax like others have mentioned, but personally I or my clients have never made the experience of a resonant tone because of ear wax, normally your hearing impression is dull or muffled, dependent on how much ear wax is in the ear canal.
3) Maybe these are otoacoustic emissions you are hearing. But if it really bothers you please visit an ENT or specialist nearby you for further investigation.
In general, I recommend every adult to visit an ENT at least once in their lifetime so he can check your hearing with a calibrated audiometer. This is nothing special and last maybe 10-20 minutes.
I hope this helps. All the best to you.
Stay focused!
