Is it me or does Apple Music sound better on a macbook than iPhone?
NiagaraPete
Jimbob54
Yep I can do that. But I prefer flexibility and usage of my iPhone sometimes. I have 2 weeks left to return the ex5. I will keep researching even if I end up with a $3,000 device.
Make your life easier. Tell us what connections and functions you want on this mythical device.
And yes, we know, you want to connect a pair of hd800 to it
AmalfiMan
AmalfiMan
Reqs:
Connect to appleTV4k without disrupting dolby vision and atmos for the TV. BT is fine for sound.
Connect to gaming PC.
Connect to macbook for lossless.
Connect to iPhone for lossless.
All with simple hookups and no hacks.
I think a receiver AVR is the solution. I will look into it.
fieldcar
Milwaukee, Wisconsin, USA
just Bluetooth stream from your iphone, Macbook and any other source you have.
wise suggestion, considering most mortals can't hear beyond -50dB of SINAD.
Source: your ears after the klippel listening test. As a broken record, I state that I cant get anything better than -39dB.
Effective SINAD of bluetooth codecs are as follows.
NiagaraPete
Reqs:
You don't have anyway to play Dolby Atmos. Unless you have a magical speaker system and Atmos decoder you haven't told us about.
Do you have something like this?
Connect to gaming PC. How about the toslink input in the EX5
Connect to the MacBook for lossless. Not ideal you should stream
Connect to iPhone for lossless. Best sound if you use the correct cable or adapter with the correct cables.
No hacks in any of the above.
Yup AVR, great choice. Buy a speaker system like the image. Make sure it supports Dolby Atmos.
NiagaraPete
Sorry I forgot you have the AirPod Max. They are the only thing that will.
AmalfiMan
AmalfiMan
I just confirmed the apple music iPhone sounds better with the schiit amp. Than using the Lightning 3.5mm dac dongle.
ok will investigate this. For Dolby, I meant retain it for my external speakers via AppleTV. But for amazon prime which doesn’t have dolby, Using headphones is fine.
Jimbob54
Presume you mean with the dongle feeding the Schiit amp- you are still using the (good) dac in the dongle - its just not powerful enough for those headphones as the only amp.
AmalfiMan
AmalfiMan
Ok so got it all to work. The EX5 usb b port is used to connect to macbook via usb c non dac dongle. I plan to get a usb hub to split it to go to the pc.
1. Why does schiit heresy have a IN and OUT RCA port? EX5 only has OUT.
2. When on the macbook, EX5 sounds awful with mac’s EQ enabled when playing some apple music tracks.
When switching to the Schiit Heresy, it sounds great with EQ.
when EX5 does sound good, with EQ on, with some songs and radio internet stations on apple music, it does have a slight richer sound than Schiit.
Jimbob54
1. The schiit is an analog only headphone amp and pre amp. You need the inputs for a dac (or CD or whatever) that already does the digital to analog conversion . The topping is a dac and headphone amp. It can be used as a one box device. It receives digital signals, converts to analog and outputs those.
2 very different devices.
2. I'm going nowhere near this part as there are far too many factors in play and I have no idea how macs work, with or without EQ. But an obvious starting point would be to ensure that in both cases, the outputs from the schiit and the topping are the same level.
NiagaraPete
Gads I thought I was going to get a day off from you but here goes.
1. The Schit is a head phone amp only. It needs a DAC RCA in to feed it signal. The RCA outs are to a amp. The EX5 is a DAC & headphone amp. It's inputs are digital "USB, Coaxial, Toslink".
2a. What sort of DAC are you using between the Macbook and Schit and what cables?
2b. Sounds like you're not connecting it correctly.
AmalfiMan
AmalfiMan
we are getting close, thanks to you man. seriously, thank you.
2a. I run the EX5 supplied USB B cable to this usb c apple multi port (usb a, hdmi, usb c) dongle. (see pic).
With the Schiit, I ran a RCA cable with a 3.5mm direct into the 3.5mm stereo in the macbook.
AmalfiMan
AmalfiMan
This article recently came out, and this guy claims the new Fiio K9 Pro ESS just sounds better then the Topping DX5:
Good:
Bluetooth 5.1 - amps supports AAC/SBC/aptX/aptX LL/aptX HD/LDAC/aptX adaptive lossless
Uses 2 separate DAC chips for left and right vs one chip
Phone App to control it's own EQ
Has IN RCA, and USB ports
Bad:
No Remote - but that's fine as I can reach the volume now.
Overall, this K9 seems to have best of both worlds of Schiit Heresy and EX5, for an extra $500 in one box........and maybe the sound is richer? lol
Link to Amazon: Fiio K9 Pro ESS
Jimbob54
Good:
Bad:
Yes, you posted a whole thread on it. The relevance to this thread being...?
AmalfiMan
AmalfiMan
Good:
Bad:
ok thanks.
My HD800s out of the box had the 6.35mm cable already connected so I been using it that way......direct plug in to the EX5 with the 6.35. I noticed there is another cable with a 4.4mm. Which should I use? (unblanced vs balanced)
Jimbob54
Good:
Bad:
ok thanks.
Does anything you have have a 4.4mm output? The xlr on the ex5 is wired exactly the same as the 6.3mm. It isn't balanced anyway.
But that shouldn't matter as the ex5 gets loud enough anyway?
NiagaraPete
Good:
Bad:
Awesome, run out and buy that as well. Send it to Amir to see if "This guy's review" is true. Haha you're killing me.
Katji
Choose the one which has the most multi-IO options.
Then you can connect everything and test which sound better.
