Ken Newton
- Joined
- Mar 29, 2016
- Messages
- 190
- Likes
- 47
Too many years knocking around this hobby has turned me from skeptic to cynic. Many of the people who seem to think DSD is the greatest thing since toilet paper on a roll are not people whose opinions I trust. But there are a few here whom I do. What say you?
Tim
DSD is a form of native 1-bit quantized sigma-delta modulation. There are a number of other forms of sigma-delta, which can vary in the number of native quantizer bits, sample rate and noise-shaping strength. In fact, nearly all D/A chips in current production are some form of hybrid multibit with sigma-delta modulation. While I'm not advocating DSD I can readily think of two objective technical advantages for it. One advanage is that 1-bit quantization is inherently linear, as two points can only define a stright line. The second advantage may be less recognized, which is that 1-bit converters don't exhibit the code dependent slew-rate distortion or the code dependent glitching exhibited by multibit converters. Of course, DSD has it's disadvantages as well, such as a very high amount of wideband noise and, if I correctly recall, greater jitter sensitivity.
One of things I find most interesting about DSD versus PCM is that the binary digital signal stream for DSD appears analog. By which I mean, it appears to change in proportion to the analog signal it represents when viewed on a scope. It resembles an FM signal, except that it's a pulse density type of modulation rather than a frequency modulation - however, the modulation of both appears signal proportional meaning, analog like. The binary digital signal stream of PCM on the other hand is a code modulation. It does not resemble the analog signal it represents. That said, I don't know that has any significance for the subjective sound. I just find it interesting to note.
