- Thread Starter
- #21
Both also canI thought you want a integrated or pre-amp.
If pre amp have volume knob must show dB
Then i can buy power amp no problem
No need pre out because inside ampThe Yamaha 803 is a nice unit but it has no pre-amp out.
Then buy the Yamaha 803. It is a nice receiver with decent amplifier design. But not as good as the Onkyo A-9070.
I using logitech z5500 satelite spealer lolWhat speakers are you using?
The Yamaha 803 and the Onkyo A-9070 will sound the same through the Logitech Z5500 speakers.I using logitech z5500 satelite spealer lol
2 channel logitech satelite speaker connected onkyo 9070 amp
Logitech z5500 amp death but satelite cannot use
I bought onkyo 9070 connected logitech satelitr speaker
Here my video
Are you sure will not diffrent sound qualityThe Yamaha 803 and the Onkyo A-9070 will sound the same through the Logitech Z5500 speakers.
Canada haha canmot
With your Logitech speakers and subwoofer they will sound the same.Are you sure will not diffrent sound quality
But yamaha weight less why but onkyo heavy weight 20kgWith your Logitech speakers and subwoofer they will sound the same.
Yes the Onkyo has a heavier chassis, more metal and a different power supply. For your Logitech speakers this will not make a difference.
