Inferior Source
MarkWinston
When listening to inferior sources like youtube, mp3, etc... do you adjust the bass and especially the treble knobs or even adjust the eq? If you do, what frequency and how much do you bump up? Are there certain frequencies that will almost need bumping in general? Its easy to overdo it, and it will be apparent on certain tracks, hence this discussion. TIA.
A Surfer
You really shouldn't. You are simply adding more chances for things to go wrong. To use a metaphor from the world of experimentation, you would simply be adding another confound making any conclusion that much harder to have confidence in. The songs themselves are the biggest factor and you will never find a global adjustment that splits the differences. Wouldn't be something I would try, personally. Just an opinion, but I'm no expert.
sergeauckland
Suffolk UK
No, so-called inferior sources firstly may not be that inferior (Spotify at 320kbps I suggest is transparent for almost everyone), but also if they are inferior, it's not due to frequency response errors that need correcting. Their inferiority, if any, is due to the nature of the bit reduction used, which still passes the full 20-20kHz bandwidth, but has more or less audible artefacts which depend entirely on the nature of the programme material. Some will be completely transparent, some will have low levels of 'burbling' (I can't think of a better way of describing it) which isn't like noise or distortion, but means that on a straight A-B comparison with the original, the bit-reduced version will sound 'different'. Note also that this 'different' isn't necessarily worse, some people have actually expressed a preference for the sound of MP3.
There is no way I know of restoring or improving the sound from these 'inferior' sources that wouldn't equally apply to the original. Once audio has been through MP3, Ogg, or whatever bit reduction, it can never ever be recovered. It will always be tainted by the process. That doesn't necessarily make it sound bad, although it might, but it will never be identical to the original.
S.
Katji
No, when it's a single track, the track would be over by that time.
Yes when it's a mix - 1 hour, 2 hours - iow, Soundcloud, much of the day - I switch between the Monitor preset and Dynamic preset.
M
MarkWinston
When I said inferior sources I mean example, some old vids on youtube, sometimes sounding very dull. So if that is the case, no bumping of anythin is still better touching any control knobs?
M
MarkWinston
Must be using an edifier, and that is definitely messing with the eq, although its way easier because it is preset. Had the s3000pro back then, it was as easy as pressing one button to brighten up dull and bad vids on youtube/sattelite tv.
Katji
It's up to you isn't it?
"sounding dull" - hence the Dynamic preset. - And you can do that with EQAPO/whatever. But I have a remote, easier.
PS: yes, exactly.
sergeauckland
Suffolk UK
If it's an old video recording, it's quite possible it originally had an optical soundtrack, with a limited HF response. In which case, it's perfectly legitimate to use a bit of treble boost from tone controls, but bear in mind that lifting the HF will also lift noise and distortion, so there will come a point where the overall sound is worse. That's why QUAD amplifiers had very good filters, so that one could filter off the Hf noise and distortion from old soundtracks. It's also quite possible that whoever digitised the sound to go on YouTube used the wrong equalisation, didn't compensate for the Academy Curve on old films or otherwise got it wrong. Anything you can do to make the sound 'better' is legitimate, as it's wrong from the beginning, so you can't make it wronger.
S.
M
MarkWinston
S.
Yeah, its impossible to retain neutral tonality with dull sounding recordings if you bump up anything at all. So you either A. Forget about anything neutral and just go with your ears or B. Keep listening to a whole badly posted album like the half the tweeter is missing but remain true to the source. Some would reach straight for the tone controls, I have yet to do it but mighty tempted to. Just seeing what the cons are if I did it.
Trell
No. The artifacts lossy compression algorithms can create, are not a lack of bass or a lack or treble or anything like that. So changing frequency response to "compensate" doesn't make any sense.
Depends very much on the level of lossy compression along with said content.
escape2
USA
Keep listening to a whole badly posted album like the half the tweeter is missing.
Can you give an example of this?
I just wanted to hear it myself to see how I'd EQ it personally.
M
MarkWinston
Here are a few examples :
Notice that these songs sound very dull and flat, as if the higher spectrums were chopped off or somethin. If it sounds normal you probably have a bright system to begin with. Sorry about the last song though.
sergeauckland
Suffolk UK
No it doesn't. The level of compression has no effect on the level of HF unless very extreme, like 16kbps!
Once one gets over about 96kbps depending on the algorithm, the full bandwidth is encoded.
S
Trell
S
Did you read my post?
Katji
It has virtually nothing to do with lossy compression, the way I see it... either it sounds better with the DSP preset or it doesn't.
...That said, it starts with the EAPO.
...Although I see the speaker remote presets as crossover options, I use the Dynamic like a Loudness switch.
Trell
Er, yes, there wasn't much other than what I quoted. What did I miss?
S
The entire post? Pretty short, though: "Depends very much on the level of lossy compression along with said content. "
Wes
True, except for the matter of psycho-acoustics and individual preference. The OP will just have to play around to see what is best, or what is least worst...
