blackiridium
- Joined
- Mar 23, 2024
- Messages
- 111
- Likes
- 40
Hi everyone,
I was wondering if you had any bookshelf speaker recommendations that could be used horizontally and in a case.
I had narrowed my search to front ported or sealed bookshelves. My thinking was that this would help with them being close to the back of the cabinet. The clearance might be only 2" on the back.
I had originally decided on ATC SCM20 and even put a deposit down. After reading online and doing further research, it seems these wouldn't be the ideal for my use case.
I have a budget of up to $5k but the less the better lol. I'm in the system building stage right now so it's a blank slate. No amps although I'm most likely going to use a Class D either Nilai or something else. It's going to be paired with a MiniDsp DAC used as a preamp.
I've heard good things of the KEF R6. If there are other options, I would absolutely love to hear about them.
