Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Depends.
Part of USB is the device enumeration. Your DAC will tell your PC is is limited to 16 bit/48.
If you go into the Win audio settings this or 44.1 is all you can choose.
As long as you use Direct Sound (or WASAPI/Shared) Win knows this and resample every thing to the sample rate you have set.
If you use WASAPI/Exclusive, you bypass the Win audio stack completely. Old (say 2015) implementation of WASAPI/Exclusive will simply crash the moment you send a sample rate / bit depth /number of channels not supported by the audio device.
Modern implementations might do the same as Win, check the device enumeration and warn you if you send something not supported or resample under the hood.
