Barry_Sound
- Joined
- Jan 25, 2022
- Messages
- 215
- Likes
- 93
What happens when I feed an older DAC (16 bit / 44,1 kHz) a higher signal through USB? Downsampling? No sound? Sound but some sort of jitter?
Likely the source will recognise the limitation and downsample.What happens when I feed an older DAC (16 bit / 44,1 kHz) a higher signal through USB? Downsampling? No sound? Sound but some sort of jitter?
1. The USB interface will tell the host exactly which formats it supports, and will not accept anything outside of that.What happens when I feed an older DAC (16 bit / 44,1 kHz) a higher signal through USB?
Or will not play. Depends on source.Likely the source will recognise the limitation and downsample.
I think it's more about supported formats rather than literal ageSomething with a USB interface isn't terribly old in the grand scheme of things to begin with.
Jitter is generally not something you can hear unless it is extremely severe. Coincidentally, these ancient USB codecs did not support asynchronous USB transfers and derived their clocks from the 12 MHz USB clock. This resulted in significantly more jitter than you see in modern asynchronous codecs. Especially when playing 44.1 kHz content exaggerates this effect. Audibility of this is however questionable, but in this case not totally out of the realm of possibility.Sound but some sort of jitter?
I'd go with the manual.I was asking because of a 20 year old Perreaux DAC. I read somewhere it will only support CD quality max however the manual states 192kHz/24-bit.
Can you narrow it down?I was asking because of a 20 year old Perreaux DAC
If it's the DP32 then it should support 192k / 24 bit via USBI was asking because of a 20 year old Perreaux DAC. I read somewhere it will only support CD quality max however the manual states 192kHz/24-bit.
Yep, my really old Edirol UA25 sound interface supports 96/24 even with a USB 1 port. The Musical Fidelity V-DAC however supports only 44/24 and 48/24 via USB, at least with my Linux PC.I suspect the OP is confused as even early USB DACs usually supported up to 96khz/24bits. For tor purpose of keeping this clear and to avoid future confusion he needs to tell us exactly what DAC he has in mind and how it will be connected to the source (a PC?).
I'd tend to trust the manual...I was asking because of a 20 year old Perreaux DAC. I read somewhere it will only support CD quality max however the manual states 192kHz/24-bit.
0) USB Audio Class Digital alsa audio output interface `hw:0,0'
- device name = USB2.0 High-Speed True HD Audio
- interface name = USB Audio
- usb audio class = (n/a)
- character device = /dev/snd/pcmC0D0p
- encoding formats = S32_LE, S16_LE, S24_3LE
- monitor file = /proc/asound/card0/pcm0p/sub0/hw_params
- stream file = /proc/asound/card0/stream0
cat /proc/asound/cardX/streamX
(where 'X' is the number of your device / card ) and then look for the "Rates" entry in the resulting output.Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Thanks, its that DAC. The manual doesnt tell much, apparently USB is limited compared to Coax.If it’s the SXD2 then yes, USB is 16 bits max 48khz sampling. If you play hires material over direct USB connection to the DAC it will be downsampled to a format supported by the DAC, it should play w/out issues then. You could however use a modern USB to SPDIF adapter with this DAC and avoid downsampling as it supports up to 192kHz/24bits over coax. The specs are kind of meh by todays norms, so idk if it matters downsampled or not, as long as downsampling is correctly done.
Yeah, PCM2902… that’s one of the ancient USB codecs.Thanks, its that DAC. The manual doesnt tell much, apparently USB is limited compared to Coax.
Note that there is also a SRC4193 asynchronous sample rate converter to upsample. This will also got rid of most of the jitter probably.
I’d say, if it sounds good, enjoy!
It has an 80 SINAD, I wouldn't worry about any of thatThere are some interesting claims in the manual such as that the DAC is able to lower quantization noise of 16-bits by upsampling to 24-bits and achieve 144dB dynamic range and them being able to preserve original samples by integer 4x upsampling, which I say is BS because of that ASRC.
