- Joined
- Jan 1, 2020
- Messages
- 1,366
- Likes
- 2,050
I honestly don’t think the XS are as bad as you describe them to be. Most headphones have flaws, there is no headphone better than the other. End of the day it’s the personal taste and preferences of a person that matter the most on the likability of the headphones.Just return it and get something else. It's not like the XS is some endgame headphone anyway so why try to fix it's flaws?
The XS is one of those hyped headphones that has quite a fanbase. This kind of following is often partly result of self reinforcement bias by buyers who first went trough countless reviews before spending big bucks (for them) and want to keep on believing they made the right choice. When you have the headphones you just have to forget all the reviews and opinions and focus on if they really are worth it to YOU.
If you can fix the problems with EQ then that's good, most headphones need some anyway. But if you can't and there are other things like Hifiman QC and lacking comfort, and you can get your money back then just get rid of it and try again.
They’re definitely not end game but they’re a good choice in the planar competition.
