Onto some more measurements - I did manage to get a few readings done - I've thought through a couple of explanations but would love to get the forums input.
So the first, was having a crack at testing room reflections with doors open/closed.
For this one, I moved the couch sat the speaker at the front of the coffee table (so there was nothing between it and the double door, except the phone, microphone and boom stand). The door is 4.6m wide, with a 2.3m opening (double slider) - speaker was positioned facing about the centre of the doors. Marked up on the photo below (except all the washing, chairs etc moved):
The mic was ~ 550mm from the speaker, then the door was about 4.5m behind that. With most of the front wall being glass - I imagine this will have a fair impact on what frequencies are reflected vs which travel through?
Anyway - results are below.
Green: Doors OPEN case
Purple: Doors Closed Case
I have to admit - I kind of expected the opposite here. I suspect perhaps the higher low base may have been wind interference - or general noise outside? As I cant see how the base would increase if more sound was reflected?
The other thing that surprised me, as other than that base region... we are not really seeing any real change? With the earlier discussion on early reflections (
@Keith_W @Verig) - i was wondering, am i just not picking up the reflections here, because the peak is picked up after a half meter - but the reflections have to go 9m - then since they are not early they are not being detected?
Probably need to learn how to look at the time side of things here - but not sure if i have the tools for that?
Second test, I did a crude on/off axis test on both the tiny Klipsch satellite and the bigger Sony. Results as follows:
I've probably Ballsed this up - as I did it by setting the mic 550mm from the speaker - then moving sideways in 200mm increments (increasing distance away each time).
But for the sake of scientific discussion - first my 'reference' Klipsch speakers:
Orange: On Axis (550mm)
Red: Off Axis ~ 20 degrees
Green: Off Axis ~ 36 degrees
Blue: Off Axis ~ 48 degrees
Seeing not much change in the base - through to about 12 dB at 10KHz.
And the Sony Speakers:
Light Blue: On Axis (550mm)
Purple: Off Axis ~ 20 degrees
Dark Blue: Off Axis ~ 36 degrees
Magenta: Off Axis ~ 48 degrees
Similar sort of change in the base - but a much smaller reduction in the treble.
I'm guessing that the 'tighter' spread between the two speakers could be:
1) Simply the Klipsch being a MUCH smaller speaker outputting considerably less energy;
2) The Sony speakers have larger domes - so you get more 'throw' of sound? (I'm guessing there is probably a proper term for this.... but i dont know it!.
I do find it interesting that generally the peaks and troughs (I.e. 200 , 250, and 7K) seem to have a larger spread of sound energy than other areas. Would be really interested in any theories on why this might be the case?
I'm interested in playing a bit further with time and reflections. I found a 'spectogram' and 'LeQ' function which look like they Might(?) allow some measurement with time. WIll read up on those and maybe have a play through the week.
Thanks again all for the great input and support thus far
