JP
^^^ what he said... and the cantilever will also bend in response to that force over time.
Ya, forgot about that one - the suspension can take on permanent compression.
My understanding of antiskating is that it is modulated by how much drag the stylus experiences when it tracks a record, and loud passages produce more of the drag effect that quiet passages do. So antiskating is at best just an average amount of force that may be either too much on quiet passages and too little on quieter ones.Thanks again on the anti-skate stuff. But as my arm doesn't have the adjustment I'm just not bothering to think about it. As I've mentioned, once I set my cartridge up well with the protractor everything sound stellar, from start of record to the end. I don't need to introduce anything more to be neurotic about
This is my understanding as well, but it doesn't negate the other effects and make anti-skate unnecessary. It's an imperfect solution to an imperfect format, so yes it's a generalized way to help improve tracking. Just like the best your can hope for in a pivoting arm is to have two points of perfect stylus to groove alignment on an entire side of a record.My understanding of antiskating is that it is modulated by how much drag the stylus experiences when it tracks a record, and loud passages produce more of the drag effect that quiet passages do. So antiskating is at best just an average amount of force that may be either too much on quiet passages and too little on quieter ones.
the subject is complicated..inextricable
but this approach on a blank track by accepting a slow glide is a really easy and easily available method for those who don't listen to too much highly modulated or demanding music... (or when listening on a mono harpsichord sound , piano "cool"etc)
she was adopted by many friends listening to jazz rock..
but if some perceive lateralized distortion on a daily basis... it may be necessary to switch to a stronger a-s... see, by minimizing the force applied as best as possible, on a 12db like that of the ultimate or recente hifi-news etc...
maybe test lp will soon appear with classic 300- 315hz for its settings but at lower modulations.. 1.8-2.5cm/s ?
the friends are measuring to have fun again
(there was a very funny test in the 70s playing on very close frequency beats, interesting .. but I have to check at what level it is modulated)
the concern, as in many other audio stories, is what is theorized.. and what is actually actually perceived by each other according to practices etc...
the irony in the case of the as.. is that thinking creates a symmetrical wear..we have done exactly the opposite for decades by considering the extreme cases of modulations....very very little encountered.
but,
to say that not an interest .. I find it a bit silly
but yes, like the alignement of cartdriges on non-linear arms... only factually relative...
that's for sure..
I agree that with all its shortcomings, antiskating is still useful, even if you apply just the minimum amount. And for all its defects, the LP medium has no right to sound as good as it does. With all its warts, you'd think it would be just plain unlistenable.This is my understanding as well, but it doesn't negate the other effects and make anti-skate unnecessary. It's an imperfect solution to an imperfect format, so yes it's a generalized way to help improve tracking. Just like the best your can hope for in a pivoting arm is to have two points of perfect stylus to groove alignment on an entire side of a record.
That's the lesser part of the problem. The main damaging effect - the irregular wear of the needle, mainly on the inner, left side - on the diamond is due to the forces generated by the angle error when using tangential arms.My understanding of antiskating is that it is modulated by how much drag the stylus experiences when it tracks a record, and loud passages produce more of the drag effect that quiet passages do. So antiskating is at best just an average amount of force that may be either too much on quiet passages and too little on quieter ones.
Yeh, I agree records can sound pretty great even with their puny bandwidth.I agree that with all its shortcomings, antiskating is still useful, even if you apply just the minimum amount. And for all its defects, the LP medium has no right to sound as good as it does. With all its warts, you'd think it would be just plain unlistenable.
I don't see records' BW as being puny; It gets out to 15kHz at least, and going to 20kHz BW gets little, if any additional audible information. Of course, not all LP playback equipment may achieve that, but a properly set up 'table, arm & cart can. The biggest problem with LP playback regarding bandwidth is that the high frequency tracings in the grooves get worn away after frequent plays.Yeh, I agree records can sound pretty great even with their puny bandwidth.
measurements, white noise (?), of f-r on a 33rpm (see 45rpm) with constant arm- cartdrige (and little worn disc) according to the position of the test on the disc...with a drop in the linear speed?
