Help connecting Edifier Mr4 and Vulkkano Sub10
ShardySk
Hi I recently bought the Edifier Mr4 speakers, I got a deal with the vulkkano sub10 and I bought that aswell but I'm a total newbie so could you guys please help me to connect those to my pc ? Also I don't have a dac or an amp, will I need one ? Thank you in advance
Which PC are you using?
If it's custom-built, which motherboard does it use?
Msi A320m-pro e
Using your current equipment, you have two options for connecting the MR4 and subwoofer:
1. Use a 3.5mm to RCA adapter plus two RCA Y splitter cables to connect both MR4 speakers and the subwoofer to a single Line out port on your motherboard's rear I/O
Basically, these three connected together:
59e78192ef8def012b68dd2dc08f0d0c.jpg_960x960q80.jpg_.png->71nt9tEWSPL.jpg->klotz-kt-cc150-rca-phono-cable-1-5m_1_ACC0008220-000 (1).jpg
2. Use your motherboard's 7.1 surround functionality to connect the two MR4s to one 3.5mm output jack and the subwoofer to another jack.
For this, you will need to install the correct audio driver, afterwards there should be a pop-up whenever you plug in a 3.5mm plug, asking what kind of device you just plugged in.
Option 1 has the advantage that no matter what content you'll listen to, the subwoofer will always play and provide deep bass response.
Option 2 has the advantage that, once configured, you'll be able to watch movies and TV shows with the LFE channel being correctly routed to the sub.
View attachment 419966->View attachment 419965->View attachment 419964
Thank you, I ordered the cables, I will let you know.
So if I got this right for option 1, the 3.5mm goes into the mobo, then the rca y splitters connect to the rca of the 3.5mm, then the rca of the speakers connect to one splitter and then the rca of the sub connects to the other splitter, right ?
How about to macbook pro m1 basemodel, is it possible ?
Yes. Any 3.5mm output can be used.
If you have an old Walkman or iPod for example, that would work as well.
