staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,017
- Likes
- 12,861
No. The surround sound tech is built into the Apple TV.I can only buy AirPod Pro 2nd generation without APPLE TV?
this is also the problemI have difficulty wearing AirPod (infantile cerebral palsy)
For proper surround with stereo headphones or IEMs, HRTF processing is required. That's what the Apple TV and the devices in the list above are doing.it is the dacs that give the suroound not the headphones?
with these devices any stereo headphone becomes suroound?@musica
I found some devices that may give you good virtual surround sound and lip sync without having to buy an Apple TV.
They're all DAC+Headphone Amp units with Toslink/Coax in and virtual surround processing built-in.
However, further research is required to make sure that they will actually work with your LG OLED to turn surround sound into virtual surround sound.
Here's the list:
- Sound Blaster X-Fi HD: older "SBX Pro Studio" Virtual Surround Sound tech, unsure if it supports >2.0 input via Toslink
- Sound Blaster X4: not sure if 7.1 input is supported via Toslink, or only via USB. Not sure what surround sound formats can be decoded.
- Sound Blaster GC7: not sure if 7.1 input is supported via Toslink, or only via USB. Not sure what surround sound formats apart from Dolby Digital can be decoded.
- Sound BlasterX G6: can accept Dolby Digital and 5.1/7.1 via Toslink and turn it into Virtual 7.1 . Doesn't support "Super X-Fi" though. Does that matter?
- Sound BlasterX G5: no Dolby Digital, no Super X-Fi, but 5.1/7.1 in via Toslink -> Virtual 5.1/7.1 out to headphones is supported. What formats can be decoded?
- SteelSeries GameDAC: can do Surround in via Toslink -> DTS Headphone:X v2.0 out. No info on supported formats.
- ASTRO MixAmp Pro TR: supports Dolby in via Toslink ->Dolby Audio sound processing out to headphones. No further details given.
Ideally, yes. But as I said, further research is required to make sure that your TV will output surround sound in a format that the devices in the list can decode and process into virtual surround sound.with these devices any stereo headphone becomes suroound?
can these devices be connected to the tv without using a pc?@musica
Here's the list:
Yes. They all have Toslink input and can function without a USB connection.can these devices be connected to the tv without using a pc?
Well I guess that depends how well it's mixed down to stereo.then good stereophonic sound is also good for films on headphones?
I bought the Sound Blaster GC7, it arrived, how can I test it to see if its virtual 7 1 is good?@musica
Here's the list:
Plug it into your TV using Toslink and set it to Console mode.I bought the Sound Blaster GC7, it arrived, how can I test it to see if its virtual 7 1 is good?
now works, but what happens when the dolby led is on?On my LG E7, I have these two settings that must be set up properly so that the correct audio format is output:
View attachment 316661 View attachment 316660
then the GC7 is successfully receiving Dolby Digital Surround Sound from your TV and decoding it.now works, but what happens when the dolby led is on?
