Headphone listening
dtomamichel
I have a Topping DX3pro+ which I send my flac files via bluetooth from Samsung S23Ultra. Would I have better sound if I use the c to usb? Any help would be appreciated
JSmith
Algol Perseus
Using what BT codec?
Whilst LDAC is likely transparent audibility wise, it is still technically lossy compression.
Bluetooth 5.0 LDAC
Hi-Res Audio Wireless and LDAC are supported with a Qualcomm QCC5152 chip. Unlike other DACs that decode Bluetooth codecs with the Bluetooth chip, the DX3 Pro+ uses the ESS ES9038Q2M chip for decoding for even better performance.
JSmith
Doodski
The S23Ultra is using the newest Bluetooth CODECS I read. They are supposed to be very good. I use them with my Buds 2 Pro earbuds and it sounds fantastic. Otherwise if you are a purist the USB-C or USB will be technically better but not sure if you can hear that difference.
D
dtomamichel
Thanks
