Yes, I was going to say, for this genre, better to buy CDs and rip. [Assuming shipping/post is ok for you.]
No way rip to MP3. Lossy compression (data lost, it cannot be re-created, magic does not exist.)
I think you are confused about it because the ripping program you know is designed or set up to produce MP3.
Ripping extracts, decodes, data from CD. The output format is WAV or maybe AIFF Apple equivalent.
The next step done by the ripping program is compression to whichever compressed format. Which are available depends on the ripping program. Apparently most of them have the audio compression codec/s built-in.
EAC (which you should use unless you want to purchase dbPower) ...EAC calls [or invokes or runs] the flac.exe program [or LAME for MP3]
You can configure EAC so that it does not delete the WAV file/s after creating the flac file/s. So you cam keep the WAV files on backup storage if you like.
And then create flac files or MP3 files from them whenever you want.
I prefer that way because I can control the version of flac.exe and options, instead of whatever the developers of whatever ripping software developers/s chose to do.
When you get to doing it, we can help you, I can post pics/description to illustrate.
