Gustard X26Pro Review (Balanced High-end DAC)
taner
When I turn it on, PCM44 kHz is installed. Let's try an experiment with your DAC. Disconnect ALL cables except the mains power cable. And turn on the DAC. What will be on the display, DSD or PCM 44?
When there is no connection, PCM 44.1 is on screen. Whenever USB is connected, it becomes "DSD 24.5 MHz" even though there is no any playback with such rate or kind.
hifidrummerguy
For me, when I plug-in my PowerMac directly I get 768hz. This is without playing anything. This makes me think that your PCs ability to play a specific quality is part of the equation when it comes to playback quality
vassago
In my set up in the dac display appears dsd 24.5 when I turn on it.When the streamer plays in the display appears pcm
Zimbalo
Italy
My setup: RPi4 connected via USB to DAC, connected via XLR to integrated amplifier
When I turn ON, in the DAC desktop appears this sequence:
PCM 44.1 (for a few seconds) >>> DSD 24.5 (for a few seconds) >>> PCM 44.1 (stable)
Veri
Don't make it up if you don't know.)
What? By all means share your superior knowledge. What did I make up? Or is your knowledge secret and not to be shared? :rolleyes:
The Altera FPGAs widely used are for digital input reclocking/routing and for better digital performance than off-the-shelf parts. Feel free to prove otherwise.
foxtrot
Then it is very likely that there is high frequency noise in your mains and surrounding equipment. Which includes the DSD mode. After that, I would try to connect the USB PC to the player and then turn on and observe in which mode the player turns on. Then also separately connect your amplifier. If we can identify the source of the interference, it is possible on the connecting wires (all including network) to put ferrite beads.
foxtrot
Intel MAX2 !!! )) Altera was in the last century)
Why should I explain something to you? They don’t pay me for this, and I don’t see any point in pouring information into anywhere. I'm not a troll. Спасибо! Do svidaniya
Veri
Most audio devices, modern ones, have an Altera FGPA. Chord uses Xilinx. Do you know of any one that uses an Intel MAX2? And idk, you tell me I make things up but don't want to share your own info, that kinda hurts your credibility.
taner
Why it should include DSD mode? This is not the first DAC I put in same environment. Even those USB powered ones didn't have such weird picky condition. This thing only appears with X26 Pro.
I disagree on this. Instead taking such measures, X26 Pro should put itself on UNLOCK mode if there is no any data on first power cycle, just like how it behaves on other digital inputs. Then it should detect the mode right after playback starts. Somehow this DAC can't follow this simple sequence on USB input. I consider this is a design error and must be fixed by @gustard .
foxtrot
Well, what to talk about? Intel bought Altera a long time ago. But I leave you to find out for yourself who buys Xilinx))))
foxtrot
Wht it should include DSD mode? This is not the first DAC I put in same environment. Even those USB powered ones didn't have such weird picky condition. This thing only appears with X26 Pro.
To our regret, Gustard does not know that X26pro owes us something)) Therefore, we ourselves need to adapt to X26pro)))
Veri
AMD bought Xilinx, got it :D but I still don't know where you were going with the "modern players have FPGAs installed, I wonder why". It isn't rocket science from source side, you never sent FLAC or APE or WAVPACK straight to the DAC everything is unpacked to PCM (or native/DoP DSD).
I reiterate, the FPGA has nothing to do with file formats. So besides what has been said already, what do you suppose the FPGA is good for?
foxtrot
You are making progress in the right direction! Please continue on! This information is very interesting)
foxtrot
Guys, please move this FPGA discussion to another thread.
I think so too.)
Try it all the same as I said. This will give both you and the manufacturer conviction curvature X26pro software. And it will make you take up the elimination of problems. Although there is an option that you need to increase the hardware noise immunity of the USB input.
foxtrot
By the way, I solved some of my problems on my own. Which were described in the first post. But in any case, solving my problems, I realized that the receiving part of the USB X26pro has problems. Which must be eliminated by the manufacturer. By the way, Khadas Tone2pro with the same XMOS216 does not have these problems. In any case Gustard need to modify the firmware software of hardware related to the digital inputs!
And with all the other DACs (very many from different manufacturers) there have never been any problems !!! This is definitely a mistake of Gustard X26pro!
Veri
In any case, Gustard needs to finalize the XMOS216 firmware!
So, on-topic. People here have been giving concrete examples and there is a firmware fix for the DSD problems. You so far have given no examples (besides your age-old foobar not working properly). What needs to be finalized? What is not working for you in XMOS216?
Gustard can't do anything to help you without more detailed/specific info. They can't read your mind.
taner
Hope @gustard doesn't follow the thread as the same way you do.
taner
I don't understand what you're saying. I'm just trying to determine what XU216 problems the X26 Pro supposedly has.
Please don't flood this thread and don't create unnecessary traffic here. I'm sure you can find more suitable threads in this forum for your needs.
