Great speakers, cheap drivers?
Ilkless
Singapore
I only bring it up because most high end drivers are treated more like jewelry than clockwork. At this point it's as likely to inspire my criticism as my curiosity. For example, I know the Philharmonic BMR is a top-quality speaker design, but the $400 tweeter almost makes me suspicious at that point. Not the $25 midrange, but I see the ribbon and think "hand spun gold wire by tibetan monks in a nitrogen purged EMI sheath" instead of a perfect horizontal dispersion pattern. Maybe ASR is rubbing off.
The RAAL in the BMR is the much cheaper 64-10D for OEMs, not the 70-10 for DIY (or the higher end 70-20 for OEM).
D!sco
Oh yeah, the BMR is a stellar deal all around. Top quality stereo for $1-3K. Wish they had an active version, and that I could hear the tower.
D!sco
You've gotta be kidding me @mightycicadalord
I might believe you, but I'd have to find my jaw on the floor after.
mhardy6647
Like for example, I can go buy the JBL 2414H-1 for about $60 on amazon. Most decent quality compression drivers land firmly around / above $100 (USD).
Therefore, I would define that JBL driver as cheap, since I can get it for cheap.
Oh, it's adorable!
A pipe flange that says JBL on it! ;)
Marc v E
The Netherlands (Holland)
This thread is a real eye opener to me!
Apparently high cost drivers are not needed to get great results like in the d&d and genelec 8361 (?)
D!sco
It also helps if the manufacturer controls the design, production, and application of each driver at every level. IMO always the number one compromise to DIY design, and why I don't get people chasing the KEF LS60 like they're going to do significantly better overall.
3125b
Germany
I think economy of scales is a big factor here, that makes a huge difference in per unit cost. Buying an off the shelf driver that is manufactured in large numbers will always be cheaper than to develop and build your own (as a small to mid-sized company, aming for the same kind of performance).
Where it becomes interesting is when a speaker manufacturer aims for something that cannot be accomplished with off the shelf parts. The KEF Reference One Meta for example, you just can't buy a coaxial that good.
genelec 8361
Those are custom drivers, aren't they? Probably not cheap per unit, absolutely speaking they don't sell a lot of them.
Marc v E
True. I should have said d&d and kii3
AwesomeSauce2015
Oh, it's adorable!
(Picture removed to shorten)
Yeah, but it's one nice sounding pipe flange!
I mean, the JBL Studio 580s might not be the absolute greatest hi-fi I've ever heard, but they certainly are impressive once you set them up right and crank it a bit.
dfuller
Not at all. Even cheap drivers are pretty decent these days.
Barefoot uses a $25 Dayton midrange, a $20 Peerless tweeter, and 2 $52 Peerless woofers on the $4000/pr Footprint01. That speaker overall behaves itself distortionwise pretty well.
mhardy6647
1) actually the forum s/w will truncate images for you; you don't have to do it.
2) An itty bitty compression driver from JBL just seems sort of... ironic. Like a subcompact Bentley, you know (and, yeah, yeah -- I know about the Mini, but they ain't even all that Mini any more ;) ).
Not sure I'd call either one great, but definitely not cheap, then or now.
jonfitch
I think the Swan D2.1 was a popular speaker back in the day (mid 2000s) using drivers that were just a couple bucks a piece.
test1223
Yes there are many very good cheap drivers.
If you would like to get a tight guaranteed tolerance band of 0.xdB or 0.x% distortion a cheap driver becomes very fast a more expensive driver. Therefore it is sometimes a fallacy to assume company xy uses driver yz therefore the cost of one driver is very cheap...
Even drivers with higher build quality didn't cost an insane amount of money. Like the tweeter of the Kii which isn't cheap in the context of tweeter price and build quality.
I would consider under 25$ cheap dome tweeters over 100$ are expensive mass production tweeters and over 300$ are the luxury class tweeters with exotic / unusual solutions and (almost) no mass production.
Sokel
I was always wondering what kind of drivers can go from 30Hz->400Hz fairly undistorted,like the ATC ones for example and many more in 3way configurations.
That can't be cheap,I'm I wrong?
