Big thanks to Roland for reaching out via the GGKNT website.
Now I have access to the controller via USB…. these speakers just went from awesome - to awesomer (am I allowed to make such unsubstantiated claims on ASR?!
Now I’ve ditched the DAC and the Minidsp Open DRC I was using - and am just using a little streamer with volume control directly into the M1 digital input!
I’ve also hooked up the TV and lip sync is perfect so far (sometimes that can be a bit of luck with my set up)
The 3rd party controller has a really nice easy to use interface with visual PEQ filters (10 band for each channel I think?) - and you can make changes on the fly and sync them to the device in seconds.
You can also save multiple sound profiles and easily switch via the controller (I’m thinking late night mode / movies mode?
Input gain is also adjustable which was great as before, my Spotify via iPhone was at a decent level with the volume at 0
And a whole host of other options I haven’t been brave enough to look into yet (FIR anyone?!)
As this is ASR I will make the effort to post my own measurement where I reduced a giant room mode. They’re now super clean and the bass is just right / tight / as heavy as it’s meant to be on the recording without getting in the way of the rest of the FR range
Once again - amazing little speakers, superb fit and finish, reassuringly chunky cables and connectors, tucked away in corners, only sticking out 20cm from the wall IN TOTAL (Kii three would be about 60cm out minimum)
Let me know if any real world questions from anyone considering them.
Kind regards
Jamie
